2wd rear badge position
Old Jul 6, 2010 | 09:42 PM
zedtechs's Avatar
zedtechs
Default 2wd rear badge position
Hi guys can someone with an original 2wd take the measurements of the sierrars and cosworth badges from the edges of the boot, have a set of new badges but don't know where they are positioned, cheers
Old Jul 6, 2010 | 11:38 PM
Cossie_ray's Avatar
Cossie_ray
http://bbs.rsownersclub.co.uk/showth...badge+location
I am not sure if the 2wd sapph and the 4wd sapph have the same badge locations.
Old Jul 8, 2010 | 07:51 AM
You may even be able to see the original marks in the paint if you look at an angle, this is how I found mine, then did by eye.
Old Jul 8, 2010 | 10:02 AM
opposite lock's Avatar
opposite lock
just had a quick measure on mine, as you stand behind boot , the badge is roughly 3.5 cm from bottom lip and 8 cm from right edge of boot
hth
Old Jul 8, 2010 | 10:54 AM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Old Jul 8, 2010 | 07:25 PM
opposite lock
sorry guys ive given the ford badge measurments pic above should give the answer
Bailes1992
Sep 3, 2015 02:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Red_bull
Aug 9, 2015 08:34 AM
