No fuel to injectors
Old Jul 5, 2010 | 06:45 PM
Cameron's Avatar
Cameron
Default No fuel to injectors
As above, just changed fuel pump and filter and now i have no fuel to the injectors, where do i start next?
Old Jul 5, 2010 | 09:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Make sure it's going into and coming out of the new filter, if not look at the pump/filter, if is then look at the metering unit.
Old Jul 6, 2010 | 06:59 PM
Cameron's Avatar
Cameron
Cheers, could i be right in thinking its an air leak? as before i changed the parts it would run for about 20 seconds then cut out and take ages to start again, then when you came off the throttle it would instantly die
Old Jul 6, 2010 | 09:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats is very very likely yes!
Old Jul 8, 2010 | 07:02 PM
Cameron's Avatar
Cameron
Right i've found the airleak, one of the breather pipes wasnt tight on the inlet manifold, sorted that, took banjo off before the fuel filter and no fuel is even getting to there, any ideas?
Old Jul 8, 2010 | 07:19 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
maybe a manuell bleed if there is one
Old Jul 8, 2010 | 07:21 PM
Cameron's Avatar
Cameron
where would i find that
Old Jul 8, 2010 | 07:25 PM
haz87's Avatar
haz87
You've fitted the fuel pump connectors on the right way? Otherwise it might be forcing the fuel back into the tank rather than sucking it out
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
cos elle
Sep 16, 2015 06:37 PM
tib2220
Sep 14, 2015 12:33 PM
