General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
my vdo electric one read the same as our workshop mechacical one lol mine has a new sender that screws into were the old one dose with 2 terminals on it one for the light on the dash and one for the gauge as for temp i have again a vdo electric one with a sump plug with a 1/8ntp hole in it that i got from ebay for the sender again works very well!
Electric ones can be 100% accurate, after all we all trust the CTS, to read correctly and keep out fuelling right which works on EXACTLY the same principle, ie thermistor.
I like and only use lecky ones due to there being NO way a mechanical oil pipe supply to the gauge can break!!
2wd can be used with sandwich plate AND temp and pressure sender if you want, otherwise just buy suitable extension from existing pressure switch hole.
I have a drilled fitting on my sump for a temp sender, as well as on oil cooler, on the nearside, loads of room there.
If you send me a sump plug I'll drill and tap it 1/8 NPT-27 for you FOC, also got 1/4 NPT-20 size taps, this is the pressure switch size used on the YB, also got 5/16 and 3/8 taps in LEFT hand tap as well as right if anyone needs a adjuster rod making up etc.
The ones I've been looking at are from demon theives. smiths with electrical senders, don't know what the smith gauges are like. Has anybody used them?
google vdo from merlin motersport as i say ive had no troubles with mine and i have an oil pressure oil temp and a 3 bar boost gauge when mine was last set up it was set at 2.6 bar of boost and the vdo gauge sits dead on 2.6 bar the temp gauge readings are realistic and the pressure gauge was as i say the same as our workshop one!
