FK Coilovers
Hi,
Iv got a set of FK coilovers and when they were fitted the adjuster was fitted at the top of the spring. I have noticed that the ride height is the same as my eibachs (bout 30mm). I just wanted to check, is the adjuster in the right place or shud it be at the bottom of the spring? Its just wen they were fitted apparently there was a seat for the sprong to sit in so the mechanic fitted them this way round.
Any help or any idead why they are not sitting as low as they shud (60/70mm) and they are meant be on the lowest setting
thanks in advance
Matt
thanks in advance
Matt
