What paint for bare metal?
Old Jul 1, 2010 | 05:54 PM
mattseries2's Avatar
mattseries2
Default What paint for bare metal?
As title, im doing some welding on my escort and need to know what paint i should use on the bare metal?
Cheers!
Old Jul 1, 2010 | 05:56 PM
RichieST's Avatar
RichieST
You'd probably want to use etch primer first, its available in an aerosol from Halfords. It will chemically etch into the metal to provide a good bond
Old Jul 1, 2010 | 05:58 PM
white2lsr's Avatar
white2lsr
If your welding I would primer everything with weld through primer before hand. Then seam seal it all, prime it up and paint it.
Old Jul 1, 2010 | 06:00 PM
mattseries2
All the welds are going to be ground back though so would it come of when doing so?
Old Jul 1, 2010 | 06:18 PM
airbrushfx's Avatar
airbrushfx
depends what your welding but heres what i do at work
1. grind off all paint on and around the affected area
2. cut out or grind rust away
3. weld up or weld plate
4. grind down welds if required
5. etch prime the area
6. filler or filler primer or primer depending on finish
7. sand back and prime ready for paint etc
this is the basics to every weld repair,
weld primer is only really needed if you intend to either weld outside (not recommended) or welding over a period of time
Old Jul 1, 2010 | 06:23 PM
white2lsr's Avatar
white2lsr
i recently cut the rot out of the boot floor on my rs turbo (see my project thread) After I had cut it all out I primed it all with weld through primer, i then made the plates and sprayed weld through primer on the back of them. Otherwise you end up with bare metal behind the repair which will rust sooner than if primed.
You can then finish it off however you want.
Old Jul 1, 2010 | 06:58 PM
mattseries2
Ok chaps cheers for the replys!!
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
