Quickie about setups
Old Jun 30, 2010 | 08:23 PM
kermitt's Avatar
kermitt
Default Quickie about setups
Engine was setup running fine before rebuild at 15psi. After rebuild I have wound the bleed valve in to minimise boost during running in dunno if I should have adjusted the actuator or anything else to suit. Car seems to run ok but don't want to give it death till setup properly. Also it seemed to pop a bit in third while giving it a bit of welly and seemed hesistant.
I don't know if this is cos its new and tight only just done 140 miles so far and its smoking on deceleration but has new turbo on it. I would imagine its either the valve guides or the rings have not fully seated yet but hopefully it will sort itslef out with more mileage.
I need it setup but it is booked in for 21st July with Dastek or Bosch (whatever they are called nowadays) and getting really impatient as I need to put alot more miles on before I can do more track days. However both Sitech and AVA are about an hour away each. Am I ok to run the car without a full setup cos am gonna have to drive to either location??
Or is there somone nearby Dunfermline that can give a helping hand and check it over for me first so that I have more confidence I can actually reach the tuners without breaking down??
timsrs
Nov 13, 2018 11:48 AM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
