headgasket
Old Jun 29, 2010 | 10:40 PM
brahe123's Avatar
brahe123
Default headgasket
hi has anyone used a 120" cometic headgasket to lower the compresion ratio on a cossie?
Old Jun 29, 2010 | 10:53 PM
botters's Avatar
botters
competant bodger
have not heard anything good about cometic headgaskets mate there other gaskets are ok tho
i deffo wouldnt use a thick gasket to lower the compression tho seems like a bodge to me
Old Jun 30, 2010 | 03:54 PM
Why do you want to lower it ?, do you NEED to lower it, higher CR is much better off boost, esp with decent mapping.
Old Jun 30, 2010 | 10:26 PM
brahe123's Avatar
brahe123
yeah the heads been skimmed what about a decompresion plate to bring the deck height back,has any1 used these?
Old Jul 1, 2010 | 04:02 PM
If it's just a regular skim of the head/and or block no need to worry, won't raise CR enough to need decomp plate, depending on what cam you use need to watch valve piston clearance, unless you have pocketed pistons ?
Old Jul 1, 2010 | 04:34 PM
LHD220Turbo's Avatar
LHD220Turbo
what's the deck height of the head?
you need to be careful the valve seats are not too thin
JoeyBoyden
20
Aug 22, 2015 03:23 PM
220TC
13
Oct 25, 2004 11:22 PM
220TC
Oct 25, 2004 06:03 PM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
