2wd Cossie Headgasket
Old Jan 18, 2005 | 03:57 PM
Daveyboy's Avatar
Daveyboy
Default 2wd Cossie Headgasket
Im in the process of removing the head off the saph. For all those that have done this before.... do you leave the exhaust manifold on when you take the head off, and then remove it after? or have you found a way to get all the nuts off the underside without the use of a chainsaw
and for those that have already aided me in my quest.... i thank you
Old Jan 18, 2005 | 04:11 PM
Alvyn's Avatar
Alvyn
leave it on and get Kola to give u a lift
Old Jan 18, 2005 | 04:13 PM
Daveyboy's Avatar
Daveyboy
you mean Cola methinks
Old Jan 18, 2005 | 04:21 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i normally split the exhaust manifold at the elbow with the 4 bolts and remove the damper. it also takes a lot of weight off that you don't have to lift with the head.
Old Jan 19, 2005 | 11:43 AM
Daveyboy's Avatar
Daveyboy
sorted now cheers fella
mark r
Sep 29, 2015 07:27 PM
arfurski
Sep 26, 2015 10:39 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
