rs turbo missing but clears under boost
Old Jun 28, 2010 | 06:26 PM
baz4077's Avatar
baz4077
Default rs turbo missing but clears under boost
Drove my escort home from work gave it a bit of stick in third and started missing and throwing out black smoke of exhaust. But then when u come back on boost clears untill i come off throttle and on again.When i rev it in neutrul misses all the time no white smoke just black. Seems to be electrical cap and rotor are nealy new have a spark on all cylinders.Has anyone had this problem i suspect plugs took them out and gaps seem fine and they look ok ANY HELP APPRECIATED THANKS
Old Jun 28, 2010 | 06:41 PM
Chopshop85's Avatar
Chopshop85
Have you tried cleaning up the points in the cap? what about the leads are they newish?
What boost are you running on what ECU?
Old Jun 28, 2010 | 08:19 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Timing ?
Old Jun 28, 2010 | 09:49 PM
baz4077's Avatar
baz4077
i am running a bajoo ecu leads are nealy new same as cap .have found that the miss is on number 2 seems to have good spark from lead to plug thinkin maybe done headgasket between 2 and 3 gonna do a compression test tommorow and put in new plugs only had new engine in for two weeks running 1 bar .had so mutch bad luck last week blew turbo monday put on another blew gearbox thursday put in another now this week problems keep commin the joys of ownin an rs turbo
Old Jun 28, 2010 | 10:01 PM
botters's Avatar
botters
competant bodger
black smoke is usually excessive amounts of fuel or unburnt fuel in the dodgy cylinder
Old Jun 28, 2010 | 10:13 PM
baz4077's Avatar
baz4077
i under stand that that is why i suspect a faulty plug but why does it clear slightly under boost
Old Jun 28, 2010 | 10:42 PM
botters's Avatar
botters
competant bodger
i would say that under boost there is more air to compensate the fuel, perhaps its just overfuelling on the one cylinder is it efi or mfi?
Old Jun 28, 2010 | 10:45 PM
botters's Avatar
botters
competant bodger
just a thought while its dark out just go and start the car up and look under the bonnet, it is a good way of the checking the plug leads as you will see them arcing out if they are knackered
Old Jun 29, 2010 | 03:30 PM
baz4077's Avatar
baz4077
couldnt do that last night babywas asleep would of woke her missis would have gone mad put a set of plugs in to day and done comp test problem fixed was the plugs bit strange thanks for your suggestions
Old Jun 29, 2010 | 11:35 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i was going to suggest plugs till i read the last post. min had been missing on cruise, but fien on boost, popped plugs out, cleaned them and made sure the screw caps which the leads attatch too were tight and all was good again.
Matt Baxter
Sep 16, 2015 08:30 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
gchristophi
Aug 31, 2015 10:36 PM
borboyous
Aug 22, 2015 11:17 AM
Neatrags
Aug 16, 2015 07:57 PM
