coughigng and spluttering
my rst has started to cough and splutter and im not getting much boost the gauge reads 10 psi but im hardly feeling anything at all .Not to sure which way to go could it be cam,timing,ignition,actuator ive fitted new boost hoses.And yesterday put a bleed valve on took it round the block and it boosted to 23 psi for about 1 second before i stopped and it wont adjust to lower it so put the amal valve back on.PLEASE CAN ANY ONE HELP ME
with the bleed valve just screw it right in and thats min boost after that you need to set your actuator iirc
also would be wort quickly pulling the plugs out and check the condition of them get a torch and check the tops of the pistons through the plug make sure everything looks ok
23psi is quite alot lol hopefully you have not done any damage
try this first
try this first
yep all on good and tight would it be worth doing plugs, leads, dizzy,rotor,and timing belt.Also i can get a -31 actuator of a pal can this just be put on then keep adjusting the rod untill it sits at 10 psi?
no it was doing it before thats why i tried the bleed valve to remove the amal from the scene .I can get hold of a timing light and the belt needs changing any way so do you think i should start there
ok ive just been to the shop and noticed i can here what6 i guess is my fuel pump buzzing all the tim i no you here it when it primes but should i here it all the time or am i just picking at things to cure the fault?
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
