Transit burnt valve
Old Jun 26, 2010 | 08:10 PM
Kammer111's Avatar
Kammer111
Default Transit burnt valve
Hi, I put my 2.3l petrol LPG transit Rear wheel drive in for a new clutch and dmf as it was shaking vilontly when the engine is under load. I thought that the dmf was to blame as there have been a few folk on here with the same symptoms as I had. Got the van back from the garage and it still vibrates in the same way. When accelerating it vibrates badly, dash, steering wheel, gearnob and crusing only a little like a wheel needs balanced but when I put my foot down on the clutch the ride is smooth and doesn't vibrate, same in neutral and slowing down.
When I got it back the mechanic said it sounds like it missind slightly on one cylinder and thought it might be a burnt valve. My questions are,
Would a burnt valve cause all this massive vibration?
Would the helicoil holding cylinder 3 spark plug have anything to do with it?
Could the gearbox be the problem as the gearnob vibrates like hell?
I started it up from cold and put my hand over exhuast and there was no suction.
Old Jun 27, 2010 | 12:09 PM
Very doubtful a burnt valve will cause all of this.
Just listen to the tail pipe for a few mins, you will hear a rythmic chuffing sound everytime the dicky valve is under compression.
Old Jun 27, 2010 | 04:27 PM
Kammer111's Avatar
Kammer111
Talking
Do you recon it's still a duff valve though?
Old Jun 27, 2010 | 05:24 PM
studabear's Avatar
studabear
compression check time, or better still cylinder leak off check
Old Jun 27, 2010 | 06:07 PM
stevieturbo's Avatar
stevieturbo
C**t
Does your mechanic actually have any diagnostic abilites ?
Even the stupidest mechanic can carry out a compression test and establish if its off a cylinder.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
