3 Door Cossie not starting
Old Jun 26, 2010 | 08:10 PM
jason_nike's Avatar
jason_nike
Default 3 Door Cossie not starting
Had the cossie out today, nice run upto Enhanced Performance (thanks for good day guys) for their rolling road day.
Drove and run fine, got home, turned engine off and went indoors.
Came out a bit later, went to put car in garage, wont start.
Turns over, but wont seem to fire up.
Fuel pump doesnt seem to work, tested for power, none.
Tested for spark (plug one out, put in spare plug, then onto rocker) doesnt seem to spark.
I am not the best mechanic around so after advice please if anyone can help
Thanks in advance.
Old Jun 27, 2010 | 09:07 AM
3dormatt's Avatar
3dormatt
Crank sensor. What condition is it in? Is the wire all broken where it goes into the crank sensor?
Old Jun 27, 2010 | 09:28 AM
adzbelcher's Avatar
adzbelcher
Wink
Thats what i was thinking common fault.
Old Jun 27, 2010 | 09:49 AM
cossieDavedree's Avatar
cossieDavedree
The fuel pump should prime when ignition is turned on ,( you should see 12V+ at the black and red wire in the boot)> + amal valve should click once when you turn the key ignition on
Almost certain its the fuel pump relay, as i have just fixed my 3dr with the same problem, yesterday
Old Jun 27, 2010 | 10:20 AM
COLEYST200's Avatar
COLEYST200
it sounds like the ECU has lost it power
Old Jun 27, 2010 | 10:26 AM
COLEYST200's Avatar
COLEYST200
have a look on this link mate it might just get you up and running again
http://www.bigturbo.co.uk/
Old Jun 27, 2010 | 11:10 AM
RS500/364's Avatar
RS500/364
Chip in the ecu see if inj 1 is on all the time !
Old Jun 27, 2010 | 08:39 PM
jason_nike's Avatar
jason_nike
Thanks for the replies all.
I am now out of my depth I believe
Old Jun 29, 2010 | 07:00 PM
Danny @ Enhanced Performance's Avatar
Unplug the ecu and plug back in,you can also unplug the plugs to the dizzy and plug back in too just to check you havnt got dodgy connection and that will reset it..
cheers danny
Old Jun 29, 2010 | 09:41 PM
jason_nike's Avatar
jason_nike
Hi Danny,
thanks for the info.
Went out to garage to try to start car.
Connected battery and it started....nice easy fix lol
Someone suggested alarm immobiliser was hot (he guessed clifford too) tapping it can fix too.
Will remember to unplug ecu tho as a good idea, many thanks
Good to meet you at the rolling road on saturday, good luck with the escort.
Got to up the power on mine at some point.
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
