Hub nuts Sapphire Cosworth
Old Jun 26, 2010 | 03:46 PM
Cossy Mike's Avatar
Cossy Mike
Default Hub nuts Sapphire Cosworth
Am I right in thinking that the Front Passenger side is also Left Hand thread, the same as the rear??
30mm nut, it wont budge and I dont have a 30 mm impact socket (yet)
Thanks
Old Jun 27, 2010 | 08:54 AM
rscos2004's Avatar
rscos2004
Default hub nuts
Thanks
Hi if its 2wd mine are about 41mm have a look at the thread you should be able to tell which way they come off.
Old Jun 27, 2010 | 11:10 AM
As said just have a real close look at the tail of the thread, if the tail thins as it goes counter clockwise it's a std right hand thread, if it thins as it goes clockwise it's a left hand thread.
Old Jun 27, 2010 | 02:03 PM
Cossy Mike's Avatar
Cossy Mike
Can't see any threads left on the top the rear passenger side was LH thread 41mm I got that off no bother but the front 30mm passenger side is causing me a bit of a headache....
Old Jun 27, 2010 | 05:09 PM
rscos2004's Avatar
rscos2004
Default hubs
Im just doing the same job you need someone with a big metal bench and a big vice as an air gun wont touch them.
Old Jun 27, 2010 | 06:15 PM
Cossy Mike's Avatar
Cossy Mike
You need a powerfull impact driver I would say, mines 500Nm couple of clicks and she was off
Job done.....It's a normal thread (anti-clockwise to undo)
I done it with an impact gun and a 32mm impact socket, not bothered about the hub nut as I've binned it and will be buying new.....
Old Jun 27, 2010 | 08:16 PM
rscos2004's Avatar
rscos2004
Mine has 41mm nuts on the front.
SmudgerByName
52
Jul 28, 2016 06:14 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
lukeeboy149
Aug 22, 2015 04:29 PM
155lee
14
Aug 22, 2015 12:15 PM
yawiejon
Aug 10, 2015 08:12 PM
