Good advise wanted please!
Can anybody please give me some advise how I will fit the sump gasket whitout getting a oil leak after?
I bought a rubber gasket on ebay and followed the instruction from Hanyes manuel but still its leaking. Have anybody tried gasket on tube (silicon)?
Br Butchi
Br Butchi
LMFAO
Biggest ball ache of a job ever, with the quality of pattern sumps, gaskets, oil pumps, and rear main seal housings, nothing lines up 100%.
My advice.. if the engine is in then a little bit of superglue to fix the gasket to the bottom of the block then fit sump, do not over tighten the bolts and go round a few times re-torquing them..... then pray
lol
LMFAO
lolwell when i had to do mine i didnt seem to run into any problems so i guess i must be lucky
