smoking
ok i have put the car back together and its smoking, the problem is when you start it after its been parked up for a while or left to cool down if you drive the car the smoke clears but when sat at the lights and stopped when you go back on the throttle to pull away it smokes again just a puff then nothink it doesn't always do it. there is no smoke on boost or when you let off the gas, i have done a compression test and cold its 6 bar and when warm its 8 bar, i have checked all the group a breather system and this is clear the inlet and head and every think was chemically cleaned i have had new bronze valve guides fitted along with new stem seals and had the valves re cut new mountune multi layer gasket arp nut and stud kit all new gaskets for top end. is this head gasket re useable ?
if you leave the car parked up for a bit and pull the plugs out you can see a small amount of oil in the bowls of the pistons all 4 i will be investigating it tomorrow with a bore scope but any help would be great
pistons were not new this time round they have done about 5000 miles since they were replaced with genuine cosworth wrc items there was not any wear on bores at all, just very weired that its only all 4 piston crowns started it this morning and no smoke will drive it again later and see and will have a look with the bore scope
ok just done the leak test and the readings i got were as follows
no1: 10 % no2: 6% no3: 6% no4:10%
re tested and got
no1: 8% no2: 4% no3: 5% no4:5%
also had a look with the bore scope and can't see much just a very small film of oil in the bowls of the pistons also had a look up the inlet and there is no oil there no oil in the intercooler either
what you guys think pull the engine out and strip it or any think else i can do to fix it.
to me it still sounds like valve guides but just had these done by ctm in dagenham
re tested and got
Charlie
Steve Escos
Oct 1, 2015 06:57 AM
