Ford Rs Parts For Sale (Not cosworth, or Cvh Turbo) All Ford rs parts for sale in here that do not fit in the popular Cosworth or Cvh turbo sections. Starting a topic requires you to have purchased a gold membership.
Fiesta rs1800 parts for sale
Old Jun 23, 2010 | 11:27 PM
jon_ross's Avatar
jon_ross
Default Fiesta rs1800 parts for sale
fiesta rs 1800 parts for sale and also other mk3 parts for sale. this car wasbought for the whole loom, ecu, and inlet manifold so these parts are not availible.
all parts are in good/working order unless stated otherwise. all parts are open to offer close to asking price and there will be additional postage charge ( some parts are pick up only)
parts list
black uncut parcel shelf with rubber straps £20
-40mm shocks and springs (not sure what make yet) with mounts £60
standard 1800 engine fully recon'd before sale with rs1800 cams £650
gearbox £40
black dash £25
black carpet £10
2 litre non pats mk1 mondeo auto ecu (EARS) £60
105ps SO efi inlet manifold £25
2x rs1800 throttle bodys £40 each
anti roll bar rear axle £40
headlights (4 sets) £10 each
brand new never fitted flowflex gearbox mounts £50
pair of fog lamps (one has a bit of the black sorround broken but is not noticeable when fitted) £15
gear selector £10
front anti roll bar £10
insrument panel (one has very stained white dails, more like yellow/brown) £15 each
front hubs £15 each
steering rack £20
window motors £15 each
door actuators £15 each
radiator £30
starter motor £25
alternator £40
mk3.5 rounded door mirrors £20 each
early square mirrors £10 each
blue magnecore ht leads £30
ignition coil £10
EDIS module £10
vehicle speed sensor (gearbox sensor) £20
glass £10 each
fuel pump £20
2x original ford headunits with codes £20 each
brake servo and master cylinder £10
front brake calipers £10 each
exhaust cat section £35
4 inch stainless back box £40
i do have more parts and will list once car has been striped further, thanks for looking, jon
Old Jun 27, 2010 | 08:34 AM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
price on drivers seat , but must be in excellent condition
cheers paul
Old Jul 2, 2010 | 07:45 AM
jon_ross's Avatar
jon_ross
cheers paul
ive got a pair of rst recaros that are in as mew condition but will only sell as pair for 350 as they are the mintest seats youll fund (there even good enough for concours)
Old Jul 18, 2010 | 05:56 PM
EscortMik3y's Avatar
EscortMik3y
Hi mate would your gear box fit on the 130psi engine zetec block ? Also have you got the drive shafts and hubs etc
Old Jul 20, 2010 | 12:52 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Hi, what reg / year is the car on?
CheeRS
Brian
Old Jul 20, 2010 | 09:25 PM
jon_ross's Avatar
jon_ross
the car is a 92 on a k plate.
yeah the engine is the same as yours and yes ive got it all call it 80 for cash
Old Jul 29, 2010 | 09:08 PM
ryley11's Avatar
ryley11
arite m8, how muuch for the 1800 badge on the back?
Old Jul 29, 2010 | 09:13 PM
andy130's Avatar
andy130
you could make your own concours for 100, so 350 you'll be waiting along time pal
Old Jul 29, 2010 | 09:21 PM
Slaney21's Avatar
Slaney21
Roflmaowtfbbqhax!
Any pics at all chap
Old Aug 20, 2010 | 03:24 PM
mk3 fezza's Avatar
mk3 fezza
how much for the gearbox, shafts,hubs,starter,flywheel and clutch? provifing the clutch is in decent nick basically all the bits il need for running gear for the 2l conversion on the mk3 fezza to silvertop
cheers russ
JoeyBoyden
Jan 4, 2024 02:36 PM
3drRich
Sep 13, 2015 07:32 PM
155lee
Aug 14, 2015 11:21 AM
Botts
Aug 13, 2015 04:16 PM
Bosch
Aug 4, 2015 05:14 PM
