cosworth alt
Old Jun 23, 2010 | 02:02 PM
B15Risk's Avatar
B15Risk
Default cosworth alt
this might be a stupid question but will a saff alt fit on to a small turbo escort cheers
Old Jun 23, 2010 | 05:39 PM
martysmartie's Avatar
martysmartie
99.9% sure it will at least I know for definate it will fit a YBT (BT) so there is no reason why not for yours, there probably the same anyway.
Martin
Old Jun 23, 2010 | 07:48 PM
With the small turbo being ford EEC management, it might not work, as it may be ecu controlled charge rate etc, though I don't know for sure at all, just a thought.
Old Jun 24, 2010 | 08:43 PM
martysmartie
I am 90% sure the ST did not use "Smart Charge" easy way to tell is the connections on your alternator there will be 3 alone just for the ECU if this was the case. Otherwise there will be one connection and the main feed to the battery.
Martin
Old Jun 26, 2010 | 07:42 PM
B15Risk's Avatar
B15Risk
i have changed it now still having the same problem its only charging at 11.7v has anyone else had a problem like this if so any ideas cheers
Old Jun 26, 2010 | 10:22 PM
dadscabs's Avatar
dadscabs
i know this might be daft have you checked the alt belt is correctly fitted and tight as ths would give it a low charge
Old Jun 27, 2010 | 10:25 PM
martysmartie
90% of the time everyone assumes the alternator when in fact it's actually the charging circuit that is the problem.
Is the battery light on the dash working? If not then this is your problem, this light is part of the charging circuit, it is common for the wire for this bulb to break at the alt end (Blue wire).
What happens if the charge excites the field windings which starts the charge process obviously if the bulb is not working this can't happen, if you rev to 4000 RPM this also will start the charge process.
11.7V is not charging, to charge the charge needs to be higher than the open circuit voltage of the battery so 13V +
Martin
Old Jun 29, 2010 | 11:08 AM
B15Risk's Avatar
B15Risk
the batt light is working on the dash its off when ignition is on but when started it starts to glow and stays on
Old Jun 29, 2010 | 12:27 PM
martysmartie
That is the problem, as I say the light needs to be on when ignition is switched on, it's glowing when running as the alt changes state from being an earth to giving a positive charge hence this is what extinguishes the light when charging, the bulb is working so must have a connection but I would still make sure the connection is good alt end first but I suspect you have a problem with the ignition feed to the bulb. Do all other dash lights etc work ok?
If you rev the car to around 4000 RPM this will start the charge process as well.
Martin
Old Jun 29, 2010 | 12:38 PM
D16PJM's Avatar
D16PJM
i had a similar problem with mine, when running was only getting just over 12V, it was a break in the wire to the alternater, on mine theres 2 which bolts on the back together and one had a break a bit further down.
now getting 13.8V when running
Old Jun 29, 2010 | 02:55 PM
B15Risk's Avatar
B15Risk
all other dash lights work its just the batt light
Old Jun 29, 2010 | 05:13 PM
martysmartie
Yes you need to check the live to the battery light you most likely have a broken connection.
Martin
Old Jun 30, 2010 | 10:49 AM
B15Risk's Avatar
B15Risk
if i put the blue wire on to the live wire the light comes on
Old Jun 30, 2010 | 12:49 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
dude give me a bell if you want me to come and have a look
Old Jul 1, 2010 | 04:57 PM
B15Risk's Avatar
B15Risk
cheers for all help it was the alt in the end thanks
Old Jul 1, 2010 | 06:02 PM
martysmartie
Glad it's sorted so lighting does strike twice in the same place
Martin
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
