1998 escort 1.6 wont start
Old Jun 23, 2010 | 01:33 PM
chip4x4's Avatar
chip4x4
Default 1998 escort 1.6 wont start
Hi im having a night mare with it I had the AA out they couldnt find the problem they said it was the fuse box also it wouldnt crank. Ive changed the fuse box now and fited a used ecu plus keys (inc red one) both with the same part numbers on and still no joy. Ive linked where the inhibitor relay was now i got it cranking, still no spark. Any ideas?
Old Jun 23, 2010 | 01:52 PM
botters's Avatar
botters
competant bodger
sounds like flywheel sensor to me
Old Jun 23, 2010 | 03:18 PM
chip4x4's Avatar
chip4x4
Just changed the flywheel sensor that didn't help. Just pluged the clock back in and the light doesn't go out when i turn the key in the ignition. Any ideas guys. Ive been without a motor for 2 weeks now
Old Jun 23, 2010 | 04:02 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
you still got the old ecu ? keys
i think the key reader will still be looking for the original key
no spark -----
works like this
from crank picup - ecu - coil pack -plugs
do you have a test meter ?
Old Jun 23, 2010 | 04:13 PM
pani_k's Avatar
pani_k
PassionFORD Member
PATS light constantly on whilst cranking?
Old Jun 23, 2010 | 04:37 PM
chip4x4's Avatar
chip4x4
Yes mate still have the old ecu and keys, only got 1 key for it and its not the red one. I changed the transponder that was with the ecu/lock kit i got.
i have an test meter not sure how to use it only know how to test for bad earths.
Old Jun 23, 2010 | 04:42 PM
chip4x4's Avatar
chip4x4
Just checked the light dont go out whilst cranking
Old Jun 23, 2010 | 04:45 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
if you put it on to ohms like a headphone shape symbol
follow the wire for the crank position sensor iirc it comes up near the rad there should be a conector that the wire comes into a 2 pin one
seperate the conector and put the test meter on the 2 pins thats going to the cps
then get some1 to turn over the car and you watch the meter see if it moves
see if you get a reading
basicly you have to work from 1st bit to last bit
why did you change the ecu?
Old Jun 23, 2010 | 05:11 PM
pani_k's Avatar
pani_k
PassionFORD Member
You sure you have no spark and not no fuel? Did the AA check this that you had fuel and ruled no spark?
Old Jun 23, 2010 | 05:14 PM
chip4x4's Avatar
chip4x4
i changed it cause the car died on me, this is what happend, i park up out side a job in front off my boss van left the car unlocked. my had to go out, jumped in car and wouldn't start the AA tryed allsorts of things, i got searching the web all the things pointed to Ecu not reading the key, changed the fusebox from a car im breaking, orderd an ecu kit through DN spares. Also just tryed to do an alarm test found out the electric windows aint working, think it might be a power fault to the fuse box.
Old Jun 23, 2010 | 05:18 PM
chip4x4's Avatar
chip4x4
defo no spark, also cant hear the fuel pump relay kicking in!
Old Jun 23, 2010 | 06:05 PM
martysmartie's Avatar
martysmartie
Check the PCM, and the main fuses in the engine fusebox, depending on where in Croydon you are I am willing to help you so long as my petrol is covered
Martin
Old Jun 23, 2010 | 06:29 PM
pani_k's Avatar
pani_k
PassionFORD Member
Unless the PATS of old is different, iirc PATS kills the feed to the fuel pump so you have no fuel pump. But sounds like you have some electrical failure going on there. If you can't sort it then next step is to take it to an auto sparky.
Old Jun 29, 2010 | 08:52 AM
completelocks's Avatar
completelocks
Locksmith
if the pats light is on constantly and it wont crank, its the keys.
You cant just swap the ecu and then use the keys from the car the ecu came from. But not all is lost.#
Get in touch with an auto locksmith and just get him to reprogramme the keys. its just as if they will be 're matched' to the cars system. Tell him you have keys, they just need programming. I've been called out for this a few times
Old Jun 29, 2010 | 12:45 PM
martysmartie
Just reread this and realized you say the PATS light is on was it on when it broke down? If this is the case then the key is not paired with the car, if you have swapped ECU and keys then there is no problem, (or you can just remove the transponder from one key and fit to another).
If you look at my post history there was a guy the other day with a RS2000 who had same problem, I said it was his key, he then got his key sorted out and it now runs!
In your case I would revert to the original ECU this should sort the immobiliser issue, the other things are probably separate simple issues.
Martin
Old Jun 29, 2010 | 08:13 PM
chip4x4's Avatar
chip4x4
thanks guys for all you help ive got it working last night, one of the wires from the coil pack was broken soldered that up and it fired.
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
xr_craig
Aug 7, 2015 06:00 PM
