abs light question
Old Jun 21, 2010 | 10:10 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Default abs light question
well just working through the niggly bits to get me car 100% got my temp gauge and headlight wipers working on the weakend the only other thing is my abs light on just wanted to know is it hard to remove and clean the sensors to check if that sorts it or is better to get a garage or someone to do it cheers
Old Jun 21, 2010 | 10:51 PM
The Youth.'s Avatar
The Youth.
easy enough to remove the sensors, if the front are stuck tho your goosed as they have a habit of getting stuck and usually snap on removal, in the olden days there was planty of granadas in the scrappys to rob them off not now tho!
the backs are more surface mounted and only the bolt suround tends to break on them as the alloy corrodes and breaks the plastic.
steve
Old Jun 22, 2010 | 05:50 AM
scottyrs's Avatar
scottyrs
DURHAM RSOC
r right so fairly easy then i might try and give it a go
Old Jun 22, 2010 | 11:27 AM
Ive had my abs light come on my car a few times and its always been the osf sensor,ever since i changed the osf hub.Touch wood its been ok for the past few weeks.I always use brake cleaner and i use a screw driver to clean the gaps between the teeth on the pick up ring.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Kam B
Sep 24, 2015 10:40 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Marino
Sep 12, 2015 11:10 AM
fuzzy
Sep 4, 2015 10:11 PM
