52mm boost gauge that reads over 2bar?
Old Jun 21, 2010 | 10:07 AM
JamesH's Avatar
JamesH
Default 52mm boost gauge that reads over 2bar?
As above, are there any?
Old Jun 21, 2010 | 10:09 AM
ST Turbo's Avatar
ST Turbo
a digital one, spa? pr stack ones do i think
Old Jun 21, 2010 | 10:10 AM
jghs83's Avatar
jghs83
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
try autogauges
they have a store on fleabay
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My raceteck one reads to 2.5bar
Steve
Old Jun 21, 2010 | 10:25 AM
DAN P's Avatar
DAN P
i uesed a raceteck one
Old Jun 21, 2010 | 11:46 AM
JamesH's Avatar
JamesH
Cheers guys
Old Jun 21, 2010 | 02:36 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Steve
Shame your boost doesn't go anywhere near the 2.5
Old Jun 21, 2010 | 02:47 PM
cruzpro.com do these digital ones, can get digital to over 1450 psi if wanted, but also do more normal levels.
Old Jun 21, 2010 | 02:49 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have ZERO boost at the moment
Does hit 2.1bar when its working
Steve
Old Jun 21, 2010 | 05:30 PM
Simmo's Avatar
Simmo
Don't you want one that reads over 2.5bar James?!
The Racetech 2.5bar is very good, but I have a 60mm Collins one that reads 40psi if you want it?...
Old Jun 21, 2010 | 05:50 PM
botters's Avatar
botters
competant bodger
burton power do a ford racing one that goes to 60 psi
https://www.burtonpower.com/product_...=boost%20guage
Old Jun 21, 2010 | 07:43 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i had this trouble got a vdo one in the end that dose 3bar as i run 2.6 seems very good sits at dead on 2.6bar
Old Jun 21, 2010 | 07:58 PM
James @ M Developments.'s Avatar
nomad do a 40psi gauge, not sure if its 52mm though. very accurate.
Old Jun 22, 2010 | 11:01 AM
JamesH's Avatar
JamesH
Cheers everyone!
Is it 52mm mate?
Possibly!
I want to stick to 52mm really, unless I do away with the SECS monitor and have a single pod 60mm with boost, then make another panel to go where SECS is as won't be fully functional anymore anyway...decisions decisions!
Old Jun 22, 2010 | 01:01 PM
ajamesc's Avatar
ajamesc
Originally Posted by James90RS
Cheers everyone!
Is it 52mm mate?
Possibly!
Yes mate its a 52mm one vdo 3bar its a nice looking one too plan black and not chav looking nice and simple
Old Jun 22, 2010 | 06:15 PM
JamesH's Avatar
JamesH
This one?
http://www.merlinmotorsport.co.uk/p6...duct_info.html
Sweet
Old Jun 22, 2010 | 07:19 PM
ajamesc's Avatar
ajamesc
Yes thats the one i have im pleased with it as it gives the big scale if u run big boost levels but it dosent give a vacum reading like the racetech one it only works on pressure so normal driveing off boost the needle stays at 0 unlike others where it can have a minus scale
Old Jun 22, 2010 | 07:29 PM
Simmo's Avatar
Simmo
I like the look of that VDO gauge!
If you decide you do want the 60mm one James let me know and you can have it for next to nowt!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
