fan issues
Old Jun 20, 2010 | 03:01 PM
scoobymad2009's Avatar
scoobymad2009
Default fan issues
right here goes need sum help as much as possible ive got a mk4 escort cabby on a f plate 1.6 engine basicly when i put a fuse in the fuse box for the fan on the rad to work it seems to keep frying the fuse as soon as i put the fuse in the fan comes on but seconds later it frys the fuse?? any ideas??
Old Jun 20, 2010 | 04:21 PM
RichieST's Avatar
RichieST
Is the fan siezed slightly or is it free to turn by hand? A friend of mine had an escort and the fan was very tight to turn and that kept popping fuses.
Old Jun 20, 2010 | 04:42 PM
scoobymad2009
the fan works when i put a fuse in but it melts the fuse??
Old Jun 20, 2010 | 04:58 PM
RichieST's Avatar
RichieST
But if you go to the car and try turning the fan by hand (with engine off obviously), does the fan spin freely or is there any resistance?
And is the fuse popping or is the plastic actually melting? If its melting then you've got a poor solder joint/fitting at the fuse holder thus creating a build up of heat.
Old Jun 20, 2010 | 05:13 PM
scoobymad2009
yes mate the fans freely and yes its just melting the plastic on the fuse but nt poping it
Old Jun 20, 2010 | 06:17 PM
RichieST's Avatar
RichieST
You've got a poor joint on the fuse holder/fuse box then, which creates heat, thus melting the fuse plastic.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark_
14
Jan 16, 2016 05:27 PM
Chas
Oct 5, 2015 07:13 PM
SMILER258
Sep 28, 2015 09:04 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
