cosworth fuel pump question
Old Jun 19, 2010 | 03:41 PM
Trist's Avatar
Trist
Default cosworth fuel pump question
an 044 uprated pump is 200lph and 5 bar but a 2.8v6 pump is 6 bar? may be a sill question but could you use v6 pump on a cosworth?
Old Jun 19, 2010 | 05:44 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
its not the pressure,but the LPH that is important
Old Jun 19, 2010 | 05:55 PM
cozmeister's Avatar
cozmeister
More boost Igor!
You could, but the engine would melt as soon as you opened the taps.
Just my humble assessment of the situation.
Old Jun 19, 2010 | 09:04 PM
col93saphcos's Avatar
col93saphcos
i reckon my 044 pump said 10bar on it
Old Jun 19, 2010 | 10:51 PM
cossytel's Avatar
cossytel
The pump just moves fuel, the pressure is created by the pressure regulator, and 044 will lock out around 10 bar from memory but flow rate goes down as pressure increases
Old Jun 20, 2010 | 09:53 PM
stevieturbo's Avatar
stevieturbo
C**t
Although an 044 is quite stable to around 7 bar. It also flows more than the 200lph that Bosch suggest.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
