escort 1.8td n.reg engine removal
Old Jun 19, 2010 | 06:54 AM
tdcraig's Avatar
tdcraig
Default escort 1.8td n.reg engine removal
hi,can anyone help, im putting an engine into my car the day but do they come out the top or the bottom and are the fuel pumps coded ??????????? thankfully i have the use of a mates 2 post ramp for two days.
Old Jun 19, 2010 | 07:00 AM
cabriolet's Avatar
cabriolet
bottom has the key got a micro chip in it if yes change the diesel solenoid on pump give it ignition live feed job done this is the only coding on the pump the diesel solenoid u want has one lucar connection on it not 2 wires
Old Jun 19, 2010 | 07:04 AM
tdcraig's Avatar
tdcraig
the key is just one of them with the button for the little light,it does have a red square on the back of the key,if thats the chip i can just swap the pumps over cant i ???
Old Jun 19, 2010 | 07:28 AM
jghs83's Avatar
jghs83
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
its easy to bypass the immobilser by buying a standard stop solenoid. this will bypass your PATS. hard part is fitting the stop solenoid.
Old Jun 19, 2010 | 07:29 AM
tdcraig's Avatar
tdcraig
can i not just put my fuel pump onto the new engine ?
Old Jun 19, 2010 | 08:09 AM
jghs83's Avatar
jghs83
can do but id change the timing belt afterwards. if your using the tdi (top mounted intercooler) engine, it can be easily tuned for an additional 20bhp
Old Jun 19, 2010 | 08:14 AM
jghs83's Avatar
jghs83
have a look at
http://www.eodc.co.uk/forums/index.p...de-and-tuning/
might be some use to you
Old Jun 19, 2010 | 06:54 PM
tdcraig's Avatar
tdcraig
my old engine pulled for fun up to 120mph so im putting the turbo,fuel pump and inter cooler of the old engine onto the new one with a full timing belt kit, how do you get the extra 20 hp, i must add when i got the car there was no vacume pipes to any part of the turbo ?????? and there is still none but it still boosts
Old Jun 19, 2010 | 07:53 PM
jghs83's Avatar
jghs83
diesel tubos work in the same principle as a petrol one but doesnt create the vacuum in effect. its long boring process of explanation!!!! as long as its got an air feed, boost pipe to engine, exhaust feed, exhaust oulet and a wastegate your good. to gain an extra 20bhp, turn up the max fuel screww within the pump. adjsut the "on-boost" fueling and turn up the turbo pressure. in the link above theres other links to a video on youtube for tuning a td pug but the principle is the same for the td escort. for a good 140bhp+ get an fmic.
Old Jun 19, 2010 | 10:15 PM
tdcraig's Avatar
tdcraig
the actuator doesnt open on my car and the standard dump valve cant open as there is no vac to it ???????????????
Old Jun 20, 2010 | 06:22 AM
jghs83's Avatar
jghs83
the actuator wont open up until it hits full boost! you wont get that by just reving it. get a boost gauge and fit that into the cabin.
td's dont have a dump valve as standard, dont fit one either. total waste of £££
JoeyBoyden
Jan 4, 2024 02:36 PM
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
