Coding remote key '99 Passat
Old Jun 18, 2010 | 04:23 PM
Oranoco's Avatar
Oranoco
Default Coding remote key '99 Passat
Got a mate stuck in a bind. His remote key has dropped it's memory and no longer locks the car, problem is he's just found out he can't lock with the key.
Is there a key turn sequence to get the remote paired back to the car?
Old Jun 18, 2010 | 05:05 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Sadly not. Sharans did. But not Passats.
Saying that if turning the key in the door lock is having no effect would suggest the door lock is buggered anyway. Advise him to try new batteries in the remote. Might be lucky.
hth
Old Jun 18, 2010 | 05:34 PM
RichieST's Avatar
RichieST
Can you lock the car via the lock in the boot? I know with a few cars you can.
Old Jun 18, 2010 | 05:36 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
wd it
you need to have a key in the ignition and on then lock the car holding the key over and then press the button
i think
Old Jun 18, 2010 | 05:40 PM
Mark_'s Avatar
Mark_
find some one with vag tacho and reprogramme it
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Flatlinedan
Sep 18, 2015 12:41 PM
NC53
Sep 13, 2015 03:05 PM
