cosworth problem
Old Jun 18, 2010 | 03:57 PM
red_s1's Avatar
red_s1
Default cosworth problem
i have a cosworth and it doesnt seem to be going the way it should, when i sit with my foot on the accelarater at the 1 speed it seems like its holding back and chugs, but when i put my foot down slowly and build boost up it goes away,
anyone any ideas what this could be?
Old Jun 18, 2010 | 04:11 PM
carlo's Avatar
carlo
Is it overboosting eddie? is it all air tight? might be worth trying a set of plugs in it as well. Andrew has them on the shelf.
Old Jun 18, 2010 | 04:12 PM
carlo's Avatar
carlo
Also is it a 044 pump on the car ? the same fuel pump that came off the saph ?
Old Jun 18, 2010 | 04:16 PM
red_s1's Avatar
red_s1
yes mate its the same fuel pump that came off the saph, and i have put plugs, leads, cap,arm, injectors, air temp sensor, am lost now haha,
Old Jun 18, 2010 | 04:22 PM
carlo's Avatar
carlo
Fuck lol stick it on a trailor to andrews! take it its the correct chip for the injectors thats in it?
Old Jun 18, 2010 | 04:48 PM
red_s1's Avatar
red_s1
i mate i put standard blue injectors in with the standard ecu and the 2 bar map sensor, and it still feels like it holds back a bit, if i bring the boost in slowly it is ok,
Old Jun 18, 2010 | 07:00 PM
Fuel filter ?
Old Jun 19, 2010 | 09:55 PM
stuarth's Avatar
stuarth
or fuel lines , petrol starvation
any kinks in fuel line
ma old corsa turbo done same thing
manuel boeckx
13
Oct 3, 2015 02:29 PM
CLIVE
Oct 2, 2015 12:58 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
