msd chip rev limit?
Old Jun 17, 2010 | 06:28 PM
stu21t's Avatar
stu21t
Default msd chip rev limit?
any1 know what the std msd chip rev limits at?
i have no rev counter in my car
Old Jun 17, 2010 | 06:59 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Ive not found mine and its been way of the rev counter at times
Steve
Old Jun 17, 2010 | 07:14 PM
bad boy rs's Avatar
bad boy rs
mines 6400 and its fucking loud
Old Jun 17, 2010 | 07:27 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
cant remember my stg 3 having a limit
Old Jun 17, 2010 | 07:36 PM
stu21t's Avatar
stu21t
6400, is that all
I thought it would b more like 7200.
I was told the engine could rev to 8k when I had it built.
Might get it upped a bit when it goes back.
Would 7200 be ok? Or pointless?
Old Jun 17, 2010 | 07:44 PM
LHD220Turbo's Avatar
LHD220Turbo
mone used to bounce off the rev limiter so its more than 7k
Old Jun 17, 2010 | 07:45 PM
pete mcrash
mine's 7500 now
Old Jun 17, 2010 | 08:03 PM
ECU Monitor Enthusiast
7200 soft cut
7600 hard cut
in the MSD chip file I have
Old Jun 17, 2010 | 08:21 PM
scoooby slayer's Avatar
scoooby slayer
msd mapped my old one on standard lifters and soft cut was 7800 rpm limiter 8000 rpm, she howled and flamed like a good un
Old Jun 17, 2010 | 08:28 PM
bad boy rs's Avatar
bad boy rs
does seem low but i thought that was the limit on a original engine
Old Jun 17, 2010 | 08:40 PM
stu21t's Avatar
stu21t
Originally Posted by Flux Capacitor.
7200 soft cut
7600 hard cut
Is that my chip si? The 1 I leant you for the diagnostic/monitor programme.
That's more like what I was expecting.
Old Jun 18, 2010 | 12:10 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
you sure it is the rev limiter and not a bad missfire
Old Jun 18, 2010 | 06:26 AM
bad boy rs's Avatar
bad boy rs
yeah
Old Jun 18, 2010 | 07:27 AM
Turbosystems
Super Moderator
doesn't sound like it me
smooth cut rev limit random cuts each injector to limit over rev it will then at around 300 rpm higher cut the lot it isn't loud
Old Jun 18, 2010 | 07:41 AM
pete mcrash
..........more like a hick uppy jerky kind of thing..........
Old Jun 18, 2010 | 07:44 AM
Turbosystems
Super Moderator
this is the technical phrase for it Thanks pete I couldn't think of it lol
Old Jun 18, 2010 | 07:54 AM
pete mcrash
clever me like...............
Old Jun 18, 2010 | 08:12 AM
Just a bit of geek info....
The first smooth cut isnt designed to limit the RPM thats what the secondary hard cut does.
It is designed to warn you that you need to change gear or back off by giving the effect of a sudden moderate decrease in engine power/response.
The weber ecu's are not capable of producing random numbers of any sorts as they do not include software which allows this.
(Computers cannot produce truly random numbers but thats another discussion)
Instead the fuel is cut to each injector one at a time sequentially in the reverse firing order of the engine.
The ignition spark is provided to all cylinders regardless of rev limit.
This provides a smooth power loss with no unburnt fuel so preventing backfires.
Old Jun 18, 2010 | 11:37 AM
bad boy rs's Avatar
bad boy rs
strange deffo not a miss fire, was on the rollers lastweek for a setup and nothing was mentioned
Old Jun 18, 2010 | 11:53 AM
stu21t's Avatar
stu21t
Si?
Old Jun 18, 2010 | 03:51 PM
scoooby slayer
even standard is 6500 isnt it ?
if id had that on my last saph it would of had about 1500 rpm power band lol
Old Jun 18, 2010 | 04:14 PM
James @ M Developments.'s Avatar
dont forget the standard rev counter is shockingly inacurate.
the rev limits we set are dependant on turbocharger and engine spec, they are not all the same obviuosly.
Old Jun 18, 2010 | 04:16 PM
stu21t's Avatar
stu21t
t34.63, greys, headwork, bd14, rebuilt engine with long studs..????
roughly?
tankybaby66
Feb 6, 2016 02:24 PM
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
