Mondeo St24 "stuttering"
Old Jun 17, 2010 | 05:14 PM
orionmojo's Avatar
orionmojo
Default Mondeo St24 "stuttering"
Hi, i've just bought a mondeo st24, i know virtually nothing about post 90's fords really i'm an old skool fan. When you accelerate the car hesitates and stutters. i recall the MAF sensors on these are prone to failing. would this cause it?
It has a brand new coilpack and leads in it presumably the previous owner tried to sort it too but failed?
its a 2.5 V6 1999 / 2000.
Cheers. Joe.
Old Jun 17, 2010 | 05:21 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
yes the maf will cause it to hold back/splutter
try cleaning it with electrical cleaner and go from there
tommy
Old Jun 17, 2010 | 07:35 PM
orionmojo's Avatar
orionmojo
cheers for the reply mate, how do you mean clean it?
the electrical plug pins? they're shiney brass when i took the plug off,
or do i take the torx screws out and spray inside that with wd40?
Joe.
Old Jun 17, 2010 | 07:47 PM
Fiddy's Avatar
Fiddy
check the plugs and the tps aswel if the maf doesnt clear it
Old Jun 17, 2010 | 08:19 PM
orionmojo's Avatar
orionmojo
Cheers, i've looked it up on google and used some brake cleaner through the maf (now i know what it is ) and its 90% better but not perfect. Whats the TPS? throttle position sensor?
is the tps something you clean or replace?
Cheers. joe.
Old Jun 17, 2010 | 08:26 PM
Fiddy's Avatar
Fiddy
yeah, tps is is the throttle position sensor. its located on the throttle body at the front as you look at, black plastic connector, never hurts to check them either, as there prone to failing on V6 2.5's. id defo check your plugs aswel, if its had new coil pack and leads, which are also prone to failing, chances are, its had plugs aswel, becasue when they develop a missfire, its cheapest to expensive, so usually people start by changing the plugs, then leads, then coil pack, but it never hurts to check them, as they have long life plugs, so they last a while, and changing the back three isnt the easiest job unless you have rite extension bar and wobbley socket, so there overlooked a lot of the time.
Old Jun 17, 2010 | 09:37 PM
orionmojo's Avatar
orionmojo
Cheers dude. i'll have another play tomorow now.
i'll let you know how i get on
Old Jun 17, 2010 | 10:53 PM
Fiddy's Avatar
Fiddy
The engines are pretty bulletproof mate, im on my second V6 now, its done 105K, and it hinestly purrs like a kitten, starts first time, and goes very well for what it is. its just a case of getting to know there little problem areas, its usually one of the things mentioned above. the only major things that go wrong is the dread ticking sound that is follwed by headgasket failure, and they do like to spin the shells if the oil isnt kept topped upto maximum, or, tbh, just above maximum. a lot of the time when they spin the shells, if follows cornering at high revs, with the oil level low, they dont have a baffled sump, and suffer oil starvation, so as i said, keep a regular eye on your oil level, and keep it topped up.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
