Re fitting side trims
Old Jun 17, 2010 | 03:12 PM
benporter's Avatar
benporter
Default Re fitting side trims
Ive ahd to remove my new door trims and i need to refit them , what have people use to refit these?
ive got some double sided tape but dont think its up for the job, any suggestions?
Old Jun 17, 2010 | 03:14 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
yh i need 2 find out what will stick them down and not fall off
Old Jun 17, 2010 | 03:54 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i fitted mine with no more nails tape lol never given me any problems!
Old Jun 17, 2010 | 05:03 PM
I got my fave gasket sealant and used that, Loctite 5900 or 5910, seriously sticks well, it is actually a flange sealant, used on production lines(5910) with 5 min cure time, evenhave shelves in the garage held up with it and use it on all threads etc to seal.
Pricey but for a reason.
Old Jun 18, 2010 | 02:26 PM
R4N SS's Avatar
R4N SS
why not use the 3M double sided tape - im sure thats what they originally used.
Old Jun 18, 2010 | 02:44 PM
bad boy rs's Avatar
bad boy rs
need to take one of mine off, ( drivers wing ) whats the best way to do so ?
Old Jun 18, 2010 | 03:15 PM
R4N SS's Avatar
R4N SS
heat it up with an air gun to get the glue all soft and be careful not to bend it when prising it away from the bodywork
Old Jun 18, 2010 | 03:36 PM
AndyPen's Avatar
AndyPen
Or use proper glue remover from a paint specialist - makes it easy peezy.
Glue goes soft then can be reused when it hardens sometimes... though I would use new trim tape. If it stays on the car side it just rolls off... only I would recomend gloves - not what Liam did!
Old Jun 22, 2010 | 06:11 PM
The Crocodile Hunter's Avatar
i used 12lb fishing line to cut through the foam tape on mine mate, worked a treat!
For sticking stuff back on i just brought some automotive double sided foam stuff, i used a brand new wood chisel to get the remains of the old stuff off
worked ok for me
Old Jun 22, 2010 | 06:20 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
I would only ever use 3m acrylic tape for the trims its awesome stuff
as for removing it I used welding wire and a toffie wheel to remove all the bits tape from the car and trims
Old Jun 23, 2010 | 08:48 PM
TurboShed's Avatar
TurboShed
Cossiemodo
I find the double sided tape is too thick, they stand out proud. Mine were stuck on with this but don't look right, and are now stuck on with superglue, no-nails, impact adhesive, and anything else I find as more bits come off!
borboyous
Aug 22, 2015 11:17 AM
cameron2
Aug 14, 2015 09:21 PM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
