Mega/Micro Squirt for Yb, Loom help
Old Jun 16, 2010 | 12:52 AM
Craigorypeck's Avatar
Craigorypeck
Default Mega/Micro Squirt for Yb, Loom help
Righto, I have a YB turbo ready to be stuck in my capri but.... I have no wiring loom or ecu stuff at all. The pinto that it is replacing has had a megajolt fitted by myself that i can salvage bits from.
Or does anyone know of an aftermarket loom I can use?
Regards
Edit.....
So I need to get a loom, an L6 ecu, ignition amp and a coil pack, any thing else? Only bit I do have is the dissy.
Sorry to bore with a novice query, just need a few pointers as to what I need to get going.
Thanks
Old Jun 16, 2010 | 04:47 PM
L6 or L8 loom will be fine, just need to swap a few wires that's all, can also use the L8 ecu if you want as it is better than the L6, personally(money dependant) I'd ditch the std ecu's and just go aftermarket, never looked back since I did.
There is 4 or 5 connections needed to connect the engine loom to the car so dead easy.
If you are even thinking of a coilpack I would seriously look at prices of everything, it is possible to get a NEW ECU new loom and mapped for Ł500, so no point if hundreds on coilpack imo then Ł500 for msd setup on top, the ecu I think is from m tech, advertise on pf do a search, vastly better value imo, this isn't the ecu I went with but is a very good ecu from what I hear.
Old Jun 17, 2010 | 02:18 PM
Craigorypeck
I'll get the loom and connect it up and see what goes where and whats missing! Mtech look pretty impressive too...
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
