zetec turbo parts list
Old Jun 13, 2010 | 06:11 PM
simps's Avatar
simps
Default zetec turbo parts list
i have got a 1.8 silvertop zetec that im running in a mk5 fiesta that i want to turbo over the coming 3 months so i want to start to buy parts now im looking for 210-220 bhp.
list of parts i requirte info on?
inlet manifold?????( r s turbo efi one????)if so what about adapter plate???
throttle body??? (rs turbo one???)
idle control vale ( rs turbo one???)
dump valve???
exhaust manifold ( which one im unsure)
turbo ( t3 ok for this? or would a stage 3 t3 or similar be better???)
loom( what needs changing//// adding)
intercooler (what 1 or what size is best for me)
decomp plate where from??? (ferriday engineering?)
headgaskets (standard ford ok????)
arp headbolts
injectors???? (beige 701's)
crank breather blocking plate?(where to buy this)
oil supply for turbo from rear pressure plate(what parts are needed???
oil return fitting for sump( is there a supplier)
ecu???(ofac///ofab???? which chip would be best for me???)(will this connect straight upto zetec loom????
which radiator????
cooling fans(am i best to uprate them????)
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
