Ford Range This section is for other models in the Ford range.
zetec turbo (budget build)
Old Jun 12, 2010 | 01:24 PM
simps's Avatar
simps
Default zetec turbo (budget build)
up until the last few days i had only een considering n/a tuning for my 1.8 silvertop zetec but as i was about to spend roughly 1k on the engine over the coming month it has daunted on me to maybe turbo it.
i think i could do the conversion myself if anything get a lil bit of help for the tricky bits.
i have searched the net for 2 days solid looking up info.
this would be a budget build and i would like 200-220 bhp how much would i be looking at to do this i am roughly looking to spend no more than 1k.
i am unsure what bhp my 1.8 silvertop is running its standard apart from a k and n induction with cold air feed.( will give ford the engine number to get the exact details on the engine in my car.)
what inlet system am i best off using?
what exhaust manifold?
what turbo?
management (ofab---ofac))(how does this connect to my current 1.8 loom is it direct plug in???)
What connects to the inlet to turbo (amal valve or anything like this i.e any thing u can think of?)
decomp plate supplier????
head gasket(st170 one??????)
oil feed from pressure plate/switch on rear of block am i correct????
oil return to be fitted to top of my sump?
relocate breather???????? from bottom of block to rear or somewhere else where????????
is there a chip available off the shelf if i ring a company up and gave them my specs?
cams 2.0 cam for inlet and 1.6 90 spec one for exhaust? or just stick with current standard cams?
injectors?????/ fuel rail??????????
what would be safe boost?
Old Jun 12, 2010 | 01:53 PM
duderacing's Avatar
duderacing
Not sure where it is, but I've read a thread on here covering a lot of what you're asking, but iirc, you need to be looking at 1.5k without labour if you're serious about this.
Old Jun 12, 2010 | 02:05 PM
simps's Avatar
simps
i could stretch to that.
i will be all the conversion myself as for the only major cost will be mapping/superchip
Old Jun 12, 2010 | 02:16 PM
rs_turbo_tony's Avatar
rs_turbo_tony
skim pistons 20 thou use focus rs head gasket fiesta turbo ab ecu ,map,edis,inlet manifold',wiring loom moumts in from fiesta too beige injectors adapter plate from ferriday engineering remove existing breather and make a plate with pipe for new breather tap and dye head for t3 manifold use 130 bhp cams and motor sport developments for chip think u could do this for under a grand mate
Old Jun 12, 2010 | 06:35 PM
duderacing's Avatar
duderacing
https://passionford.com/forum/techni...questions.html
Here ya go falla. Might be of some help.
Can't give any advice myself, as I'm reading this sort of post because I'm thinking of trying this in the future. This sort of thing almost always ends up costing more than you anticipate though.
Old Jun 12, 2010 | 06:38 PM
Ginger Will's Avatar
Ginger Will
http://www.fiestaturbo.com/articles/zetecturbo/
Old Jun 12, 2010 | 07:24 PM
simps's Avatar
simps
i have already read the fiesta turbo forum guide.
im just after help with specific parts that i will/ might need to accomplish 200-240 bhp.
also advice from people who have built there own zt's as i will be doing the conversion myself im ok with the spanners an stuff but im just unsure of myself i like to be told what to do/ how to do it when it comes to engine im capable of doing the work i just like to be reassured with advioce / know how of ppl that have already done this
Old Jun 13, 2010 | 03:17 PM
2ndGear's Avatar
2ndGear
look at this -
http://cgi.ebay.co.uk/Brand-New-Ford...#ht_520wt_1139
Old Jun 13, 2010 | 04:49 PM
simps's Avatar
simps
na im looking to carry out my own conversion rather than buying one part done / finished.
i like a bit of a challenge.
im going to set myself a deadline to have all the parts by mid august as i get 2 weeks off work for august bank holiday and plan on getting the car done and finished then.
Old Jun 13, 2010 | 05:23 PM
MJ_RST's Avatar
MJ_RST
what car do you have to start with??
Old Jun 13, 2010 | 10:19 PM
simps's Avatar
simps
its a mk5 fiesta with a 1.8 silvertop in
Old Jun 13, 2010 | 10:23 PM
waynefrst235's Avatar
waynefrst235
Hi mate. I've just about finished my own zetec turbo build so if u need any advice or help with problems I'd be happy to help
cheers Wayne
Old Jun 15, 2010 | 07:43 AM
Escort James's Avatar
Escort James
i am the same as you mate i wanna turbo my gti
but all the guides you read are for 300bhp plus i just wanna do the turbo conversion myself and get it running
Old Jul 7, 2010 | 11:25 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
ditto.
i had a 1.6 cvh xr3i. running manual injection.
I chose a 1.8 blacktop but theyre pretty much same. and im aiming for 200-220bhp too.
People always say to spend thousands and it'll be good for 300+bhp. But im not after that much in a cab!
i bought a stainless tubular T3 manifold for £130 including delivery, special price. saves arsing about with cvh one as i was unhappy how badly it fitted. I plan to use cast turbo pistons from another make car.
Using rover turbo inlet and i'll be going for emerald management, purely cause i'm fussy.
Thats pretty much it really, im not on a budget as such, i dont want to spend a penny if i can help it, but i dont mind for management etc as i know its needed. Things like intercoolers can be bought for few hundred quid new, but im using chargecooler setup for less lag and easier packaging in mk4 bay with standard rad...
just need to find a decent turbo, one i bought has fucked ex housing.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
