fuel pump
Old Jan 17, 2005 | 04:35 PM
Drjones's Avatar
Drjones
Default fuel pump
I am changing me fuel pump cause mine is f**ked but not sure what pump to replace it with. I am in the middle of building a high spec zvh, some people say the standard one is fine for up to 400bhp but others say to use a saff cossie one? What you lot think????
Old Jan 17, 2005 | 09:50 PM
MK5RST's Avatar
MK5RST
saff cossie and RST pumps are exacly the same, use the standard RST pump
Old Jan 17, 2005 | 09:53 PM
Rallyesport's Avatar
Rallyesport
They are not the same, the cossie flows slighty more at 3 bar. The part numbers are not the same eiter.
Old Jan 17, 2005 | 09:56 PM
MK5RST's Avatar
MK5RST
slightly more, how much more, the part numbers aint the same but the pumps literaly are
Old Jan 17, 2005 | 09:57 PM
MK5RST's Avatar
MK5RST
How much more
Old Jan 17, 2005 | 10:13 PM
DazC's Avatar
DazC
Bosch 0580 254 941.
Fits S2 and Sierra Cosworth.
The S1 and S2 pumps are different. The S2 pump is physically bigger and won't fit in the cradle.
Old Jan 18, 2005 | 06:40 AM
Rallyesport
S2 is 0580 254 910.
3.25 l/min @ 3bar for 910
3.67 l/min @ 3bar for 941
Old Jan 18, 2005 | 12:58 PM
swerv's Avatar
swerv
why not go for a bosch 044 pump , otherwise known as the GRP A pump
Old Jan 18, 2005 | 06:13 PM
Drjones's Avatar
Drjones
what car is this for s2 or cossie
Old Jan 18, 2005 | 09:47 PM
MK5RST's Avatar
MK5RST
we are all assuming its the S2 pump as its an RST Forum
Old Jan 18, 2005 | 10:10 PM
DazC's Avatar
DazC
The 044 is neither Cossie or S2. It won't directly fit without an adaptor which can be purchased from A1 Rallye Sport.
However it is totally unnessesary unless you want over 400bhp in which case you will need the 044. The 941 will suffice up to that limit.
The 044 will flow 200l/h at 5 bar or 3.33 recouring per minute at 5 bar.
Old Jan 23, 2005 | 11:34 AM
Rossco's Avatar
Rossco
Slightly off topic (sorry )
What fuel pump for my S1 running on FRST 2.1 16v Zetec turbo, running 230-250bhp.
Any thoughts
Old Jan 26, 2005 | 08:54 PM
mrviper's Avatar
mrviper
Rossco, i need to know that aswell mate with cosie yellows
sombody tell us
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
