Windscreen removal and doors off a Sapph?
Old Jun 10, 2010 | 11:54 PM
Char1ie's Avatar
Char1ie
Default Windscreen removal and doors off a Sapph?
Any tips? I'm looking to take a windscreen off a Sapph. I have removed the plastic scuttle panel from round the windscreen wipers and I have pulled the outer seal off. What's next? Thanks.
And door removal on a Sapph. Beat the pins out of the hinges with a hammer and drift?
Cheers,
Charlie
Old Jun 11, 2010 | 12:38 AM
jon@work's Avatar
jon@work
The windscreen is bonded in isn't it ? If so, I doubt you'll get it out in one piece.
Undo the nuts from inside the A pillar to remove the doors - 4 nuts per door, and the check-strap bolt. Get ready to catch the reinforcing plates, though.
Old Jun 11, 2010 | 05:38 AM
STeve's Avatar
Super Moderator
only way to get the screen out is with either a tool called a kent knife which cuts through the glue,or using a long bladed stanley and a bottle of soapy water and slice away at the rubber from the inside,sierra screens though can be a pain if there is any rust on the lower part of the scuttle panel or the window frame itself
Old Jun 11, 2010 | 04:32 PM
Yogi.'s Avatar
Yogi.
this is what you need to remove the windscreen in one piece:
http://cgi.ebay.co.uk/WINDSCREEN-GLA...item5639f99f23
you need 2 persons for this. i removed all my windows with the wire without any damage.
chears
yogi
Old Jun 11, 2010 | 04:57 PM
Thrush's Avatar
Thrush
Irritating c........
As said, screen is bonded, so you'll need to cut it out. If you've never done it then unlikely you'll get it out in one piece - specially if it's not in great condition to start with (much pitting and/or stone chips on it)
Karl 3dr
102
Oct 14, 2016 08:17 PM
Bailes1992
Sep 3, 2015 02:17 PM
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
no1trancefan
Aug 4, 2015 12:48 PM
