cvh timing
Old Jun 10, 2010 | 12:06 PM
mark2's Avatar
mark2
Default cvh timing
hi all
hope someone can help
when setting the timing on a mfi erst s2 chipped running a bar fm/ic at 12 degrees btdc with vacum hose removed and inlet blocked at 850 rpm ,when i reconnect ecu hose the revs increase a little and the timing mark moves to 16 degrees btdc at idle is this normal ?
cheers
mark
Old Jun 10, 2010 | 03:38 PM
JesseT's Avatar
JesseT
Yes.
Old Jun 10, 2010 | 05:15 PM
mark2's Avatar
mark2
Originally Posted by JesseT
Yes.
thanks for ya reply been a great help
mark
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
s1turboman
Aug 29, 2015 04:27 PM
Ben26
Aug 27, 2015 08:56 PM
