2WD Cosworth flywheel
Old Jun 7, 2010 | 06:32 PM
MERKUR XR4ti's Avatar
MERKUR XR4ti
MERKUR XR4ti
Default 2WD Cosworth flywheel
A machine shop has just totalled my Flywheel
If anyone has any idears or a spare one I could have machined I need to move my car real soon
Is there anyone out there that could machine a new one up for me with My PCD in it .
Old Jun 7, 2010 | 07:12 PM
Sounds like a good machine shop!!
I have a 2wd cossie flywheel in good order despite 200,000K miles, ideally needs a skim, but certainly not bad by any means, just a bit blue, and you can have the friction plate free, all the springs rattle like f**k!!
Pm me if interested, I had another skimmed lightened and balanced for £30 by my machine shop so this is surplus now, nb it went from 8.9KG to 6.6KG in case you're interested, how did they wreck yours, trying to slot it by any chance they don't like this!!
Old Jun 7, 2010 | 07:27 PM
MERKUR XR4ti
MERKUR XR4ti
Thank you for your offer That would be great if I can get it off you.
I had to get the Crank PCD swapped for a 2.3 Crank and they drilled it from the wrong side, so the PCD is off I could not believe they did it and when I told them they didn't get what I was saying at all . I had to show them with a Ford Mustang flywheel what I ment Thanks Paul W. Ps where are you in the world .
Old Jun 7, 2010 | 11:11 PM
jon@work's Avatar
jon@work
couldn't you just have the (wrong) hole(s) welded up and re-drilled ?
Old Jun 8, 2010 | 04:14 PM
I'm in Norfolk, uk, carrot cruncher killer farmer territory!!
I only just seen the addy for your local, but no probs for me, think I must just have seen the wales bit!!
As jon says though cost wise would be much better in your situation/location.
Not trying to put you off have sent stuff there before, and loads to iceland regularly so not a prob if you still want, just pm me.
Old Jun 8, 2010 | 05:32 PM
MERKUR XR4ti
MERKUR XR4ti
NO Jon IF YOU WELD the flywheel will work harden like you woulden't Believe and It would cost silly money to have it re-drilled with an electric erosion bit / tool .
Old Jun 8, 2010 | 08:24 PM
AndyPen's Avatar
AndyPen
I have a spare here in Swansea... it is planned to go on a motor so you would have to replace it though... any help?
FlashRS
13
Aug 31, 2015 06:02 PM
druidgetafix
Aug 15, 2015 10:22 AM
Aug 14, 2015 07:29 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
