Engine noise need help asap!
Old Jun 4, 2010 | 10:22 PM
dazrsturbo's Avatar
dazrsturbo
Default Engine noise need help asap!
hi all. when accelarating i get a very loud ticking noise coming from my engine! i really dont know what this is!! i have changed the followers because i thought it was these that were making the noise but that isnt the case! could it be bottom end? timing? or something else! please help! cheeRS!
Old Jun 4, 2010 | 10:37 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
amal valve? detonation?? lay of the boost mate till u find the problem at least.
Old Jun 4, 2010 | 10:40 PM
dazrsturbo's Avatar
dazrsturbo
if its the amal valve how will i test this??
Old Jun 4, 2010 | 10:59 PM
Karl 3dr's Avatar
Karl 3dr
Exhaust manifold gasket leaking?
Old Jun 4, 2010 | 11:23 PM
dazrsturbo's Avatar
dazrsturbo
no the exhaust gasket is fine! all nice n snug fit! its deffo comming from the engine! its a really quick loud ticky noice on hard acceleration, and a slow loud ticking noice from pull off.
Old Jun 4, 2010 | 11:26 PM
rstdave's Avatar
rstdave
Spun a bearing maybe or piston slap.....if it's definately not coming from the head might be worth whipping the sump off and checking the big ends first, how old is the engine??
If you're not too clued up on them and you have a good tuner nearby might be worth getting them to have a listen before you go ripping things apart though
Old Jun 5, 2010 | 10:45 AM
dazrsturbo's Avatar
dazrsturbo
off to the tuners is the best bet i think!
malkiemac3579
Jul 14, 2017 12:10 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
