Indicator Problem
Old Jun 4, 2010 | 03:27 PM
NobbyXR3i's Avatar
NobbyXR3i
Default Indicator Problem
Hi, new to the site and in need of help so any suggestions constructive or not welcome lol
Ive just picked up a MK4 XR3i Cab 1988 E plate for the princly some of £350 smackers with mot lol Ive driven it 60 miles now and she is a beast and im reliving my boy racer days lol anyway the indicators dont work but the 4 way flashers do as does the main beam. Any suggestions? cheers Dan
Old Jun 4, 2010 | 03:36 PM
RS500/364's Avatar
RS500/364
explain more
sounds like your hazard relay puts on you main beam
Old Jun 4, 2010 | 03:50 PM
NobbyXR3i's Avatar
NobbyXR3i
No i mean the stalk seems fine as in the main beam part works just not indicators which leads me to think that its not the stalk but im clueless lol
Old Jun 4, 2010 | 04:14 PM
jon@work's Avatar
jon@work
Sierras use 2 feeds to their indicator/hazard stalk - one permanent (for hazards) and one switched through the ignition (for indicators). If escorts are similar, which they probably are, have a look for a blown/dodgy/missing fuse in the fuse box.
Old Jun 4, 2010 | 05:39 PM
martysmartie's Avatar
martysmartie
What he ^^ said also check reversing lights as if as said they are like the Sierra the two are on the same circuit so these would not work either.
Martin
Old Jun 5, 2010 | 03:49 PM
NobbyXR3i's Avatar
NobbyXR3i
Default cheers
Cheers i will investigate further and get back to you all, ta
Old Jun 8, 2010 | 02:06 PM
NobbyXR3i's Avatar
NobbyXR3i
I have changed relay on the stalk and there are no blown fuses either, The Hazards switch seems a bit dodgy as u have to fiddle with it to get them to kick in? Do the mk4 suffer with fuse box issues like mk5?? cheers
Old Jun 8, 2010 | 02:40 PM
pompy1's Avatar
pompy1
I had this problem with my Sierra a little while back... Changed the indicator relais and checked fuses. Still nothing. Then decided to change the indicator stalk and whey presto, no problems anymore. Just wish I'd done this before forking out for a new relais
All the best, Nige
Old Jun 8, 2010 | 03:10 PM
paulgsi's Avatar
paulgsi
just had this problem at the weekend with my sierra , was acting up exactly as described - it turned out to be the hazard switch being faulty
Old Jun 8, 2010 | 04:28 PM
It's nearly always the hazzard switch, the reason for this is the lack of exercise the switches get, ie never get used, the beeswax that they were filled with from new goes hard, jams the switches mechanically and also stops current flow across the pin terminals inside, a easy if fiddly fix, take apart spray out clean with wd40 etc drench it well, dry out with air etc, then either put in beeswax on the switches and locking mech for the up/down action or use lots of furniture polish that contains silicone(make sure it does some don't).
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
