Escort cosworth green fan relay
Old Jun 3, 2010 | 06:12 PM
cossy chick's Avatar
cossy chick
Default Escort cosworth green fan relay
Hi guys....im new on here so please be gentle I wonder if you can help me?
I need a new or second hand cooling fan relay (the green one behind the battery) on my big turbo escort cosworth. The part number is 93GG8C616AB.I have been to ford main dealer and they told me it is no longer available??? Have tried lots of breakers but no luck there either Please can anyone help??
Old Jun 4, 2010 | 03:33 PM
What numbers does the relay have next to the pin numbers, like 85 86 87 30 30/51 etc.
It may just be a generic relay and not a ford only part.
Old Jun 4, 2010 | 11:05 PM
cossy chick
This is what it says on the relay
Ford D23YA
93 GG 8C 616 AB
$89 9987 00012V
PBTP - GF 30
Made in Germany
Old Jun 5, 2010 | 12:40 PM
If you look at the base of the relay, ie so it is upside down you should see numbers next to each terminal of the relay, it is these that I need, as I suspect it is a std item fitted to lots of other stuff, that I can then match up for you.
Old Jun 5, 2010 | 09:44 PM
cossy chick
Default pic of fan relay with numbers
http://s882.photobucket.com/albums/ac26/cozzy_chick/
Hi Tabetha
Please see above link to picture of fan relay, you can see the numbers clearly on that. Hope it helps, look forward to your reply.
Thanks
Old Jun 6, 2010 | 07:38 PM
I can't quite make all the numbers out clear enough, but the numbers I could decipher it looks a 2 stage relay.
I have sent you my email, send me a decent piccie, as I can't enlarge that one, I'm crap on the compy!!
The relay is almost certainly made by bosch, if not it will be a siemens one under license, so may still be able to get one from them, may look different but do the same job.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
