where to fot dump valve
Old Jun 2, 2010 | 06:47 PM
gareth01544's Avatar
gareth01544
Default where to fot dump valve
hello i have just bought a RS500 cooler and want to fit a dump valve back on it but it has no place for it??
i was going to drill a hole on the cool side before where the hose goes on and weld a little piece of pipe on the put the 90 bend off the small original intercooler on with my bailey dump vale on?
will that work?
any ideas
cheers
Old Jun 4, 2010 | 10:31 PM
rich2302's Avatar
rich2302
what car is it on and do you know the purpose of a dump valve?
Old Jun 5, 2010 | 06:04 PM
rscos2004's Avatar
rscos2004
Default fitting a dump valve
will that work?
any ideas
cheers
Hi the best place to fit a dump valve is in between the intercooler and the inlet plenum all you need is to buy a t piece so you dont need to chop youre old one there are lots of these on ebay.
Old Jun 5, 2010 | 06:18 PM
Just get the silicone pipe with the cold side dump location and plumb into that between inlet tb and i/cooler.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
