5 bar map sensor
Old Jun 1, 2010 | 06:34 PM
t3 dan's Avatar
t3 dan
Default 5 bar map sensor
what mods are needed, if any to fit a 5 bar ?
Old Jun 1, 2010 | 06:45 PM
cossytel's Avatar
cossytel
Remap
Old Jun 1, 2010 | 07:01 PM
t3 dan's Avatar
t3 dan
so no wiring mods ? just a new chip/remap
Old Jun 1, 2010 | 07:34 PM
cossytel's Avatar
cossytel
The bosch sensor has built in temp sensor and has 4 pin connector but they make an adapter cable to convert to 3 pin minitimer try Reyland.
Old Jun 1, 2010 | 08:03 PM
t3 dan's Avatar
t3 dan
cheers mate, its reyland im gonna get it from so will ask the question to them when i ring.
Old Jun 1, 2010 | 08:06 PM
stevieturbo's Avatar
stevieturbo
C**t
Although the fact you are asking about a 5bar and dont know what's involved...is rather worrying.
Is anything else in your setup built to make use of such boost that you feel the need for such a sensor ?
And the Bosch is usually 4 bar ?
Old Jun 1, 2010 | 08:14 PM
cossytel's Avatar
cossytel
4.6 Bar
Old Jun 1, 2010 | 08:21 PM
t3 dan's Avatar
t3 dan
Just wanted to ask the question before i ring reyland tomorrow. you dont need to worry about me mate, why come on to bash my post if your not going the help.
Its people like you that piss me off on here.
Just for you information its a well speced car running the same spec as the reyland focos. and it says 5 bar on the reyland website
Old Jun 1, 2010 | 08:23 PM
bad boy rs's Avatar
bad boy rs
Does that mean you could run a poss 60 psi ?
Old Jun 1, 2010 | 08:31 PM
stevieturbo
C**t
5 bar is typically 4 bar positive pressure. So as close as 60psi as it gets.
That's a lotta boost !!
Old Jun 1, 2010 | 09:14 PM
Ima Racing's Avatar
Ima Racing
Wiring mods yes, forget temp sensor. This new version fits 2 trucks 1 with temp the other without,the key is the lead.
Old Jun 2, 2010 | 12:42 AM
3i_gaz's Avatar
3i_gaz
its obviously needed or else he wouldent waste martins time at reyland with a phonecall and the added cost of buying the fucker
Old Jun 2, 2010 | 09:50 AM
stevieturbo
C**t
Then why does he need to ask here how to fit the damn thing ?
Old Jun 2, 2010 | 09:55 AM
Dingy's Avatar
Dingy
I have a 5 bar on my l8 - mapped by nms...
2.5 bar
Old Jun 2, 2010 | 10:09 AM
Gary F's Avatar
Gary F
As do I
Old Jun 2, 2010 | 02:07 PM
t3 dan's Avatar
t3 dan
I didn't ask how to fit it. I asked if any mods where needed to fit one
And I get a bellend like you jumping all over it.
if your not posting anythink helpful don't post at all
Old Jun 2, 2010 | 02:36 PM
Dingy's Avatar
Dingy
wiring it is no different to a normal map sensor....
1 wire is 0v
1 wire is 5v
1 wire is signal between 0-5v
simple really as imatrukas said its a temp sensor as well so that would also give you 1 wire for the temp signal.
as on a cossie pressure and temp take a common 0v from pin 11 i guess there is no reason why you couldn't use this sensor in your plenum to do away with the 3 bar and the manifold absolute temp sensor - guess it would depend on scope and spec of the temp range as its for a truck LOL...
Old Jun 2, 2010 | 02:48 PM
ECU Monitor Enthusiast
1 wire is 0v
1 wire is 5v
simple really .......
.....as its for a truck LOL...
With respect, it isnt the same, as the power supply pins are reversed.
If you just plug ia 5 bar sensor into the standard loom, it will destroy the sensor at worst or at best just age it significantly.
The sensor is originally from a diesel truck and as diesels dont generate any significant vacuum, these sensors are highly inaccurate in vacuum readings to a point that it cannot read below negative 0.5 bar so attention to detail must be paid in idle mapping and closed loop control.
Old Jun 2, 2010 | 03:41 PM
Dingy's Avatar
Dingy
the plug dont fit either simon - lol but again all the wires are there lol which was my point - doesn't need rewiring....
How can the power pins be reversed as you have :-
Sensor
Cossie loom
Surely you connect the correct pins from the cossie ecu to the sensor....or have i missed somert here...
Old Jun 2, 2010 | 04:30 PM
gibbo frst's Avatar
gibbo frst
i brought the metal housing block that reyland supply for mine to fit in as didnt want to remove the plemum to drill it into like some have done.. reylands block then fits onto the original map sensor bracket..
also my secs monitor now reads the wrong boost ... ive asked before and dont thing this can be fixed..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
