Waxoyl Underseal Paint..
Old Jan 16, 2005 | 06:53 PM
McCloud 85's Avatar
McCloud 85
Default Waxoyl Underseal Paint..
Is it any good?? its the black gunky stuff you get in the tin, does it do the job well as this can be painted sraight over surface rust.
Or can stone guard be applied over rust? in which case is this the better option?
cheers dan
Old Jan 16, 2005 | 07:05 PM
Lee Reynolds's Avatar
Lee Reynolds
Waxoyl is the best protector to use. In the cavaties as well as underneath
Old Jan 16, 2005 | 07:27 PM
McCloud 85's Avatar
McCloud 85
thanks lee, looks like i will get cracking with painting that on the underside then!
Just been reading your post on your S2, top stuff!!!
Old Jan 16, 2005 | 08:03 PM
Tim's Avatar
Tim
Aye waxoyl every time i aint got the patience to paint it so as lee said
Old Jan 16, 2005 | 10:01 PM
Lee Reynolds
Get it painted Tim ya lazy fooker! Nicer to work on afterwards then too!!!!
Old Jan 19, 2005 | 01:54 AM
SS1's Avatar
SS1
Default Re: Waxoyl Underseal Paint..
Old Jan 19, 2005 | 07:15 AM
lamb chops's Avatar
lamb chops
I would paint i on as the spray gunks up every few seconds, you are supposed to leave the tin in hot water for half an hour to melt it down. If you do get the spray one stick the tin in the oven for half an hour to thin it right down, does stink a bit though.
Old Jan 19, 2005 | 06:24 PM
McCloud 85's Avatar
McCloud 85
cheers guys for the replies
i was going to use the stuff in the tin, as iv used it before. Surely if its slightly thicker then it wont go everywhere and will give you a thicker coat??
i was going to do the underside about 2-3 times anyway, to make sure i have a good seal.
dan
Old Jan 19, 2005 | 08:56 PM
Lee Reynolds
When you buy the five litre tin(like an oil can), buy the spray gun too....its like a spray lid off kitchen cleaner bottle with a long hose. To get the gun to work the waxoyl needs to be thin. You do this by standing the tin a red hot water in an old washing up bowl or bucket. Every few minutes ya need to shake the tin. As said above the stuff gunks the gun up so it stop working....easy to solve. Leave the tin stood in the bucket of hot water and move it round with ya.....just need the car high enough!
Make sure you either remove or mask the exhaust!
Lee..
Old Jan 19, 2005 | 09:59 PM
tiny's Avatar
tiny
I would treat the rust befor coating over the top, because once its sealed over it might look fine from the outside but its still rusting underneath, if u
know what i mean
Old Jan 19, 2005 | 10:38 PM
Lee Reynolds
know what i mean
oh yes definatly
IainRS1700T
Sep 25, 2015 06:44 AM
TrevCos
Aug 17, 2015 09:08 PM
twitchyrear
208
Apr 17, 2006 01:41 AM
COSSIE 1
Feb 26, 2006 10:29 AM
slowpoke
38
Nov 11, 2005 01:20 PM
