efi cut out help please
Old May 30, 2010 | 11:50 AM
onionboy's Avatar
onionboy
Default efi cut out help please
hey peeps was out and about last night and as i pulled out and started driving along my engine cut out, it felt like some one had just turned the ignition off. had a look at obvious things but everything seems to be fine. does any one have any ideas?
cheers
Old May 30, 2010 | 12:03 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
what about the fuel cut off switch ??
Old May 30, 2010 | 12:24 PM
onionboy's Avatar
onionboy
yh checked that
Old May 30, 2010 | 12:29 PM
andy130's Avatar
andy130
crank sensor? cross the fuel cut wires as they are nothing but bother tbh
Old May 30, 2010 | 12:38 PM
Ginge !'s Avatar
Ginge !
just finding my feet
i had this in my cabrio before,,,, turned out the petrol gauge wasnt working proper belive it or not
Old May 30, 2010 | 12:51 PM
onionboy's Avatar
onionboy
lol i put £20 in that night
Old May 30, 2010 | 12:55 PM
andy130's Avatar
andy130
does the pumped buzz when you turn on the keys?
Old May 30, 2010 | 12:58 PM
onionboy's Avatar
onionboy
yh thats the first thing i checked its a newish fuel pump because the other one died
Old May 30, 2010 | 12:59 PM
Ginge !'s Avatar
Ginge !
oh, is the pump priming,,, if you hear that then its gonna be ignition,, take 1 plug lead out at a time and rest on slam panel and get someone to turn over and see if you can see a spark,,, DO NOT FOR THE LOVE OF GOD TOUCH THE SLAM PANEL OR ANYTHING METAL WHEN DOING THIS !!!
if you got spark on the plugs that means the CPS is working,,,,, then wiggle other sensors about but thats where i would start tbh
1: fuel pump priming means your fuel is getting to the rail
2: spark from plugs means there is ignition so it could be weak ignition but that would start when convinced enough
Old May 30, 2010 | 01:00 PM
S1's Avatar
S1
So does the pump prime or not?
Old May 30, 2010 | 01:03 PM
onionboy's Avatar
onionboy
yh pump primes and ive got a spark checked the sensors and fuses ive checked all of the obvious things unless im missing something out.
Old May 30, 2010 | 01:04 PM
S1's Avatar
S1
check the small black unit on top of the fuel pump assembly, they burn out quite often. They can be bypassed quite easily. Edit not that then.
Check the earth on the right hand side of the engine bay, IIRC it earths the injector loom.
Old May 30, 2010 | 01:05 PM
onionboy's Avatar
onionboy
no not checked that
Old May 30, 2010 | 01:10 PM
Ginge !'s Avatar
Ginge !
if you got fuel and spark is should start,,,, you sure its priming ?
Old May 30, 2010 | 01:15 PM
onionboy's Avatar
onionboy
positive. its just weird the way its gone i would understand if there was like a big bang or something but there wasent. if i cant sort it by tuesday going to phone some one because i want to go classic ford lol
Old May 30, 2010 | 05:18 PM
B19 JUB's Avatar
B19 JUB
boss aka missis permitting ill pop over tomorrow n have a look fella.ill bring my compression tester because having fuel and spark it should start
Old May 30, 2010 | 08:29 PM
gup's Avatar
gup
do you hear the fuel pump priming when turning over the ignition
also when cranking can you hear the fuel pump buzzing after a split second
Old May 31, 2010 | 02:28 PM
onionboy's Avatar
onionboy
all done now guys. stupid little swith had uncliped so the injecters wernt working cheers for the help though guys
Old May 31, 2010 | 02:54 PM
andy130's Avatar
andy130
good to hear,
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
dms04
Sep 11, 2015 01:57 PM
