Cossie brake problem advice please
Old May 30, 2010 | 11:09 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default Cossie brake problem advice please
i put new 4x4 calipers and rear cylinders on the s2 this weekend, bled the system, normal way load on the rears etc, but my pedal travels to far nearly goes to the floor.
Any ideas what i could do to get a normal pedal travel
Old May 30, 2010 | 05:53 PM
project rs's Avatar
project rs
sounds like a bit of air stuck in the system, when i change the fluid i use a fluid of different colour to the one i'm removing so i can tell when it's worked it's way through the system
Old May 30, 2010 | 08:16 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i bled the system again and got more air out, but not great still, im puttin it down to the rear shoes.
Old May 30, 2010 | 08:44 PM
studabear's Avatar
studabear
clamp both rear hoses if the pedal comes good it prob is the shoes
Old May 31, 2010 | 09:51 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
prob being dump here but how will that work?
Old May 31, 2010 | 10:29 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
also when engine is off the brake pedal should go hard if pump it, mine doesnt it bet sniffer but not hard like it should go
Old May 31, 2010 | 08:26 PM
project rs's Avatar
project rs
deffo air or your master cylinder has gone
original
Apr 28, 2026 05:20 PM
nick8saff
Aug 16, 2015 05:35 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Red_bull
Aug 9, 2015 08:34 AM
