zetec alloy crank pulley - 7 -9bhp gain - true or false?
Old May 28, 2010 | 09:57 PM
mikehillmotorsport's Avatar
mikehillmotorsport
Default zetec alloy crank pulley - 7 -9bhp gain - true or false?
whats your view - there on ebay and i think they are a smaller diameter than std. - but what about the 7 -9bhp gain claim?
Old May 29, 2010 | 01:45 PM
Sp3no's Avatar
Sp3no
Your accesories create drag on the engine as speed increases etc, the light weight ones reduce this drag on the engine so theoretically i dont see why they would not work. I have CFM crank and water pump pulleys on mine. Make sure you get a new water pump pully that is larger otherwise you will underdrive your waterpump with just a smaller crank pully which is not good. There are 2 down sides, your lights may dim when the car is idleing and the lightweight crank pully removes the dynamic harmanisor that is on the standard pully, this is a rubber bush which allows a bit of flex in the crank, without this some say it can put the oil pump at risk as the flex can shatter the oil pump gears
Old May 29, 2010 | 02:41 PM
steve7786's Avatar
steve7786
I had an alloy under drive pulley fitted
Old May 29, 2010 | 03:11 PM
1300gt's Avatar
1300gt
It will not give your engine more power. Only lower reciprocating weight / rejuice point of inertia.
I would spend the money elsewhere. You should be careful what you buy off "ebay".
Old May 29, 2010 | 10:58 PM
packman's Avatar
packman
The big balancer pulley is there for a reason , it take removes vibration from the rotating mass of the crank this is what kills oil pump gears and it doesnt matter if you put steel gears in there eaither it will do the same.
Old May 29, 2010 | 11:16 PM
Isaac.Hunt's Avatar
Isaac.Hunt
Incorrect. If they pulleys are a smaller diameter as the original poster states he suspects, then (also as mentioned) they will under drive ancillaries thus freeing up more power at the flywheel.
Old Jun 1, 2010 | 09:59 PM
mikehillmotorsport
so basically they are just for show - next question - what camshaft adjustable pulleys are best to go for - obx, kent - what are best?
Old Jul 27, 2010 | 03:31 PM
hineho87's Avatar
hineho87
dont no if ur sorted now but when i checked people said most of the cam pulleys (kent, obx are same) but it depends if u want braggin rites! I went for OBX as got them good price brand new and they av dun job fine.
Did u go for the underdrive pulleys (crank and water pump pulleys). Iv seen CFM do a 2 piece set (link below)
http://focus.c-f-m.com/cfm2pcaluminu...csvtst170.aspx
Wot do people think? Any gud? Iv got full exhaust/induction/cams and pulleys on my 1.8 mk1 focus and just wanted make sure i got it all sorted before i get her mapped!
Thanks
155lee
Oct 27, 2015 04:55 AM
mondeomark
Alloy wheels and ICE for sale
Sep 27, 2015 09:17 AM
focuspower
Sep 19, 2015 08:27 PM
BRAM
Sep 8, 2015 07:11 AM
Ade
Sep 7, 2015 05:06 PM
