Problem with My MK3 Mondeo Ghia X deisel..
Old May 28, 2010 | 09:34 PM
Rides's Avatar
Rides
Default Problem with My MK3 Mondeo Ghia X deisel..
Right this is bugging the hell out of me...Got a 2001 MK3 Mondeo Ghia X deisel..yeah yeah I know devils fuel..but needs must..anyway when I stick fuel in like £20.it shows on the trip I have around 160miles of fuel...which is fine..but the part thats bugging me is I drive say 60miles and park up..
leave car come back get in start up, and it shows less than 50miles fuel and the light is on then after 5miles or less it shows 25miles then keeps dropping down..until it reads 0miles left..
I've taken the battery leads off a few times and then it shows then correct milage left ie 95miles or so..WTF's going on with the stupid thing, then after a while it starts doing the same thing, showing less and less milage and fuel left. Im thinking I have a problem with the clocks or the computer... as I've worked out Im getting around 40mpg..round the streets and a good 50mpg on a run..
so anyone got any idea's cause it's doing my nut clean in..
Old May 28, 2010 | 10:01 PM
rostill2007's Avatar
rostill2007
clocks are apparently a problem on these but i dont know if it would affect the fuel reading
Old May 29, 2010 | 10:31 AM
Rides's Avatar
Rides
cool though as much something could be wrong with the clocks... well fuel reading is being affected
Old May 29, 2010 | 11:21 AM
It's Czech Mate's Avatar
It's Czech Mate
Sender unit? Acessed easily under the rear bench
Old May 29, 2010 | 12:03 PM
Rides's Avatar
Rides
already tried getting it out wont fit through the hole as it's a bit big..so looks like it's tank removal and sort it that way..bummer would have liked an easier way..
Old May 29, 2010 | 12:12 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
The mpg gauges aren't particularly accurate even when they work correctly. Do you keep resetting the average mpg function, as that can affect the rest of the data - the longer you leave it between resetting the more the info is 'averaged out' and there will be less fluctuation in the readings.
Old May 29, 2010 | 12:20 PM
david 100's Avatar
david 100
My Range Rover does this , i can stop the car with half a tank then get in it later i have just under half a tank, the wifes Saab does this and so my brothers merc so i think its just one of those things, i had a Escort 1300E years ago and that done the same.
Old May 29, 2010 | 12:36 PM
Rides's Avatar
Rides
No dan not had the car long so not found out all the stuff it can do..ie resetting stuff...the only one i reset is the trip.. it's just the fuel gage is reading empty now but i know there's fuel in the tank...but not know how much is bugging me as I wont know when I'm about to run out altogether.. and then be stuck somewhere not able to get back home..
this week I've stuck around £60 of deisel into the tank but have only done around 120miles if that..so just needing to know how much is actually in the tank..
never had any problems in my RS not once with fuel readings..wish i still had it...sadly written off..gutted
Last edited by Rides; May 29, 2010 at 12:38 PM. Reason: just adding more to the post
Old May 29, 2010 | 03:00 PM
James's Avatar
James
sounds like fuel sender problem. my mate had similar problems with his petrol mondeo and he replaced the sender which was about £40 iirc from ford.
and yes, despite a hole under the seat you will have to droop the tank.
Old May 29, 2010 | 03:25 PM
Rides's Avatar
Rides
cheers will have a look at it once the weathers better ie no rain..
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
imnoteasy
Sep 7, 2015 09:26 PM
Adam Graham
Sep 6, 2015 06:04 AM
Bighandsuk
Sep 2, 2015 05:23 PM
