Dump Valve.........
Old May 28, 2010 | 07:44 AM
Hoogi's Avatar
Hoogi
Default Dump Valve.........
I'll be running the follwoing spec Engine and wonder if anyone can advise which would be a good Dump Valve to use - GGR, Bailey etc.
RS500 Block Long Studded
Polished Head
14 Inlet Cam - 10 Exhuast Cam (Mountune Spec)
GRP A Pistons
H-Beam Steel Rods
Balanced Crank
T34 .63
Siemen 55lb
-31 Actuator
Coil Pack etc on M.D. Chipped P8
Many thanks
Old May 28, 2010 | 12:14 PM
jon@work's Avatar
jon@work
the T34 doesn't need a dump valve to be fitted
Old May 28, 2010 | 05:46 PM
Although it doesn't have to have one fitted, it makes a hell of a difference if it has one, I disconnect mine occasionally for the chatter that me lad likes, so much slower in the gears.
I use a Colins group a one, a diaphragm one, as these seem to be louder, so I drilled mine out to be as loud as possible as well!!
Old May 28, 2010 | 06:11 PM
Hoogi's Avatar
Hoogi
Thanks for the replies Gents...........
The reason I was asking is I thought it kept the Turbo spinning at higher revs by relieving the back pressure to the turbo when you're off the throttle between gear changes.
I also thought this could prolong the life of the turbo "a little" with a little whooosh as a bonus
Old May 29, 2010 | 03:22 PM
It does release built pressure and so aid in re-spool so reducing lag, this is why I run with one.
Old May 29, 2010 | 05:23 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
any they all do the same release air pressure on let off so it dosent go back to the turbo and stall the compressor wheel more of a thing with high boost levels! but wont hurt on any if u can put up with the noise lol
Old May 30, 2010 | 03:18 PM
I thought I would get fed up of the noise, but I haven't, still love it guess I must be a chav at heart!!
Old May 30, 2010 | 06:14 PM
ajamesc's Avatar
ajamesc
Im lucky mine chatters but then i do run 2.6 bar
Old May 30, 2010 | 10:49 PM
forevaford's Avatar
forevaford
KOOL how fast is 2.6 bar?
Old May 31, 2010 | 08:54 AM
I didn't want to chance 2.6 bar on a 200,000K old engine, but once new one is run in after 1000 miles boost back up around 36/38 happy days!!
Old May 31, 2010 | 02:27 PM
ajamesc's Avatar
ajamesc
very on my gt30
cossie09
Oct 11, 2015 06:29 PM
DAZZER
Sep 30, 2015 08:43 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
