what do i need to convert zetec s with puma engine
hi all need abit of help[list]
1. does a 1.6 ford fiesta zetec s eco work with a 1.7 puma engine an do yo need the key. 2. does a fiesta zectec s 1.6 gearbox fit the 1.7 puma engine. 3. does the fiesta zetec s wiring fit the 1.7 puma engine. 4.do you need the 1.7 fuel pipes an can 1.6 fiesta zetec s pipes be used thank all
ecu
engine loom
transponder + key
engine
you can use you 1.6 box and drive shafts
you will need a TAPE ECU if your dash is digi or a MUFF if it is analogue
engine loom
transponder + key
engine
JoeyBoyden
Jan 4, 2024 02:36 PM
Oct 9, 2015 07:38 PM
lockie
Jul 31, 2015 10:03 PM
