smoking
hi
my brother has a s2 turbo and when its started from cold or has been driven and left for a couple of hours upon start up theres blue smoke which then clears after a minute or so.
what would be causing this?
many thanks
mark
many thanks
mark
As said above the oil is seaping past the seal's and when its started it burns off the oil giving the blue smoke that then clears
Some heads can be changed while still on the car with a special tool so no need for an expensive job .
Steve Escos
Oct 1, 2015 06:57 AM
