What turbo and housing is this? (pict attached)
Old May 27, 2010 | 04:38 PM
dave_s2_rst's Avatar
dave_s2_rst
Default What turbo and housing is this? (pict attached)
Hi all as above...also is my manifold knackered ? see pict with arrow.
cheers
Old May 27, 2010 | 05:14 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
pics aren't great, one of compressor housing is of little use to be honest, the overall pic shows it's a cossie exhaust housing, possibly a 2wd cossie turbo, or a hybrid of an escort rs turbo on a cosworth exhaust housing at least.
what is the A/R on the exhaust housing?
if 0.48 it's the same as a stage 3 t3 turbo for an escort.
as for manifold, could just be a casting imperfection, they don't tend to crack as a rule unless running mega lean. If that is the case your pistons should be on the way out too.
Old May 27, 2010 | 05:27 PM
rsmark86's Avatar
rsmark86
it says a/r .42 on it aint that a standard 2wd turbo
Old May 27, 2010 | 06:28 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
the escort rs turbo also has a compressor A/r of 0.42, as does the 2wd/4wd ones.
it's not the A/R that's different, it's the compressor wheel size/trim and housing that is different.
Old May 27, 2010 | 10:02 PM
dave_s2_rst
whats the best way of checking this? Also is it worth keeping the cossie housing? Reason being, im going to be getting the exhaust sorted (additional hangers and poss a flexi put on) and will therefore be getting a downpipe sorted
Old May 28, 2010 | 09:05 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
The Turbo setup on the car is the best for free flowing on the std setups so keep it as it is if its all working.
However fit an intercooler.
Old May 28, 2010 | 11:07 AM
dave_s2_rst
Cheers ,
Definatly need a proper front mount so I can ditch the crappy chargecooler
Old May 28, 2010 | 11:08 AM
dave_s2_rst
One more thing, should I get a spacer plate made between the manifold and turbo housing as it seems to be very close, if not touching
Old May 28, 2010 | 11:27 AM
Versus_Creations
Ask me a question!
no just grind the alloy a little but dont go made.
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mrknifey
Aug 30, 2015 11:48 AM
jaimesdna
Aug 25, 2015 06:59 AM
