focus rs mk1 help
Old May 27, 2010 | 03:23 PM
kieran265's Avatar
kieran265
Default focus rs mk1 help
hi i have a frs mk1 with cat back exhaust, pannel filtter and bluefin.
the actuator was knackered so was replaced with a forge 1, the pproblem is the boost still drops down and then back up and stays there. any ideas why it would do that, also with blufin what psi/ bar should it be running.
thanks kieran
Old Jul 25, 2010 | 09:56 PM
kieran265's Avatar
kieran265
any1?
Old Jul 25, 2010 | 10:06 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
you have a leak?
Old Jul 25, 2010 | 10:09 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Prob runnin 18-20 psi spike?! ish.
Common leak in the breather hose behind the block with the white valve in it?
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
massivewangers
30
Oct 1, 2015 07:40 PM
richierich1986
Sep 18, 2015 03:29 PM
JamboRS
28
Sep 14, 2015 09:02 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
